Who has the most aggressive set up
Hey I was wondering if anyone knew which car on the forum has the most aggressive offset. Im asking because im about to go very aggressive and want to know if there is any fender work needed or anything I should be aware of.
... that doesn't quite make a lot of sense, you want to go aggressive but are un-aware if you'll need to do fender work?
couple of guys have done 19x11 with like +10? but either had custom widened rear quarters, or radius'd rear fenders. even mine at 9.5 +22 i had to roll and pull the rear quarters.
i think a fitting quote for this is:
if you want to play, expect to pay!
hope that helps?
hope that helps?
yeah i realized it didnt make sense after reading it again but i cant edit... what im asking is what fender work needed to be done.
i know i have to do it and dont mind getting work done i just want to start planning ahead of time
the wheels i have coming in are 19x9.5 22 front and 19x10 24 rear
thanks for the reply
^^ uhhh?
as for your front 9.5 +22, use a 225/35 tire and youll just need to crush the inner edge of the fender up flat, very easy..
rears you will prolly just need to roll nice and flat and maybe pull a bit, depends on what tire you want to use, and what height you want to be at, my new rear wheels i plan on doing a 10.5 +22 and using a 235/35 tire, while having my tien SS maxed low, and i dont think i will need to make much more adjustments to my body from what i did to make the 9.5 +22 with a 235 fit.
and just so you know these sizes and offsets are not considered "most aggressive".
check out vipTL or Decafe1, they have done some good work.
Retired!!! ON TOP!!!
DecaFe1 will soon have the most aggressive offset ever on a TL...
Go and look at his Build thread https://acurazine.com/forums/3g-tl-photograph-gallery-96/new-wheel-projects-updated-7-15-a-756086/
It will give an idea of how much work it'll take to fit certain wheel specs on a TL...
Good Luck...
As of right now... I'm running F: 19x10 +3 (235/35) and R: 19x11 +6 (265/30)
Good Luck...
LIST/RAMEN/WING MAHSTA 짱
Go and look at his Build thread https://acurazine.com/forums/showthread.php?t=756086
Good Luck...
Good Luck...
wow 10 +3 front?!
have you done some work to your front fenders?
heres rodney's with the specs he just posted for reference
and thats on air.
and thats on air.
Yes, absolutely... the front fenders were worked on...
Check my build thread from a couple of years ago...
https://acurazine.com/forums/3g-tl-tires-wheels-suspension-97/stance-almost-there-732944/
