Where to go to have locking lug nuts removed
Old Dec 20, 2002 | 10:29 AM
nameeri's Avatar
Allright, got a question for everyone.
I have two locking lug nuts that cant be removed for some reason. Either the acura dealer over torqued them or something, or they have just seized on, they are impossible to remove. The key was detroyed trying to remove them. And btw, if you have purchased cheap locking lug nuts for your wheels, purchase a set of Gorilla locks immediately or you will find yourself in my position. So, where can i ge in So Cal to get the damn things removed? Any help would be greatly appreciated. If there is someone I can call, please post the number, Thanx
Oh yeah, Americas Tire company already tried to remove them with no results, there just isnt enought room for a larger extraction wrench to fit, my wheels already got all scratched up when they tried to remove the locking nuts, so now i have to get that fixed too!!
Old Dec 20, 2002 | 03:22 PM
StanMan's Avatar
same thing happened to me a month ago or so where either the tire shop cranked it down tight or the rusting was very bad. you have to drill out the stud so the lug can fall off...you then remove the rotor and replace the studs. i tell you, it sucks! my wheels ended up getting scratched around the lug openings and it cost $100!!! make sure you choose a good shop to get this done...i might not have incurred and wheel damage.
Old Dec 21, 2002 | 03:53 PM
Lawaia's Avatar
Moderator Alumnus
Use of anti-seize compound on the studs will ease in removal. If you haven't already done so, now is a good time.
Old Dec 21, 2002 | 04:02 PM
is300eater's Avatar
I Shoot with a Camera
I thought that all tire places would know better than NOT to use a torque wrench.
Old Dec 21, 2002 | 04:08 PM
what is a torque wrench? what i mean is what is the difference between a torque wrench and the tool that comes with the car to loosen the stock lugs?
and why not use a torque wrench??
Old Dec 21, 2002 | 04:17 PM
is300eater's Avatar
A torque wrench can be set so that it prevents over tighten of a bolt or nut... I guess it senses by pressure.
Old Dec 23, 2002 | 10:55 AM
StanMan's Avatar
good shops that use air tools should also have something called a torque stick...it's an attachment that prevents overtightening.
Old Dec 23, 2002 | 03:39 PM
Edward'TLS's Avatar
6G TLX-S
Everytime someone, including Acura dealership services, put on my lag nuts, I'll always go straight home and use my torque wrench to re-torque all the nuts to the proper tightness. This will prevent rotor warping from over or under tightening of the lag nuts. You'll be surprised by the variation in tightness between each nut on the same wheel.
Old Dec 23, 2002 | 06:54 PM
how tight should the lugs be torqued, wut is too tight??
Old Dec 23, 2002 | 11:04 PM
StanMan's Avatar
based on the stud specs, it should be 80 foot pounds.
Old Dec 23, 2002 | 11:28 PM
Edward'TLS, where can i get one of these torque wrench for my TL in richmond??
*note- dun wanna get it from dealer( even if they have one for sale) since dealers jack up the price quite a bit
Old Dec 24, 2002 | 12:32 AM
Gilgamesh's Avatar
TL-99, go to the tool section of Home Depot, Sears, etc... its just a general tool, take in your lug key to make sure it fits the wrench you buy. That is it...I have one hanging around for changing the blade in my mower :-P
Old Dec 24, 2002 | 03:33 PM
Edward'TLS's Avatar
6G TLX-S
I bought mine in Sears almost ten years ago. They carried two types of wrenches. One was the more expensive ratchet type, and the other was the more common needle pointer type.
For the ratched type, you set the desired torque by turning the dial at the end of the tool's handle. When the set torque is reached, the gear inside will go click, click, click without turning any further.
For the needle pointer type, you read the torque by reading from the printed scale on the tool pointed by the twisted needle pointer. If you buy this type, make sure you buy the one with the long handle, because the short-handled one is not capable of the 80 lb/ft of torque required.
Marcelechka
Home & Garden
188
Sep 11, 2022 11:53 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
DementiaPhuro
Sep 29, 2015 05:31 PM
Desert Ridge
Sep 27, 2015 02:37 PM
