Wheels Spacer Help...
Here's 9.5 +35mm and yours will be another 3/8" farther out so I don't think you'll need a spacer.
https://acurazine.com/forums/3g-tl-tires-wheels-suspension-97/3-months-wheel-fitment-research-i-missed-little-bit-811518/
You are already pretty flush. Another 10mm could be added but you would have to pull fenders and switch to 225 tires
.... unless of course you are still riding at near stock height. Then lowering it would be first priority over any spacers
at 8" width you have a lot of room to play with. My set up was pretty aggressive to start with being a 1.5" wider than yours and lower offset. I was safe at 5mm to put me at +20 offset, but you can go thicker. Be careful though, you may have to get longer studs if you go beyond 10mm.
jmoney2001
Sep 11, 2015 12:07 PM
mtl_ilx
Sep 3, 2015 09:48 AM
