Wheel Fitment Sticky?
Hi All,
I'm pretty new to Acurazine. I have a wheel fitment question for an 06 Acura TL and wondered if there was a sticky somewhere about this. I found this tread:
https://acurazine.com/forums/3g-tl-t...-04-tl-807669/
It was helpful, but I've got a few specific questions for the flush guys out there. A lot of folks look like their running 33+ to 38+ offsets. My questions are:
1) How low of an offset can you run on an 18x9.5 wheel and still fit a 245/40/18 or 235/40/18 on all four corners? 2) I would expect to have to roll the fenders, but would a pull be necessary too? 3) How many inches can I lower the car with only slight camber?
I'd rather go with a little higher offset if it gets me more tire, but still want to be close to flush. Looking to balance some aesthetic with grip here.
Any help would be greatly appreciated (even pointing to other threads is helpful).
Thanks!
Thanks!
Welp, this thread pretty much mirrored what I'm planning to do, so pretty much answered! (Thoughts are always helpful anyways though)
https://acurazine.com/forums/3g-tl-p...-909769/page2/
A few points to ponder.
1. Every make/model/size tire is different.
2. Every drop amount is different, and even different per corner.
3. Every car is different.
Given these 3 facts, there are literally infinite possibilities for a set-up to not work, so the ONLY reasonable course of action is to find someone who already has what you want, or nearly what you want and use what they use, tweaking from there. No reason to re-invent the wheel.
The following 2 users liked this post by VisualEchos:
Boosejars (01-01-2017),
DarkTower19 (01-03-2017)
This car is running almost the set-up I want:
![](https://cimg0.ibsrv.net/gimg/acurazine.com-vbulletin/2000x1064/wheelfitment2_649fc77e1fa615688b41702ae628ea6813600768.jpg)
I'm looking at the same wheels and similar offsets. This car is running 19x9.5+25 in the rear and 19x9.5+38 up front (w/ 5mm spacer). Tire size 235/35/19
Some variations though: 1) I'd rather run an 18in wheel over a 19in wheel and keep more sidewall. 2) I want to run the same offset (under 30) and tire size at all four corners. I just want to run 245's at all corners. I was thinking Hancook Ventus V12s.
But you're right, so many variables there's a ton of reasons if might not work.
![](https://c2.staticflickr.com/2/1603/24899178824_32d6daee0f_o.png)
Carbon Dark. by Andrew Thompson, on Flickr
Right. lol
You really need to find something closer to exactly what you want, I'm sure it has been done before. Before I purchased my wheel/tire combo I did 6 months worth of research, then still ended up getting the wrong tires, selling them, then finally getting the right ones for what I was after. I lost a few bucks, but it was worth it
This your ride? Beautiful car. I've seen it in the wheel fitment sticky. You're running like +40 and 265 tires, right? The TL seems to contradict a lot I thought I understood about wheel fitment. I suppose every car varies a lot, but I'm coming from 10 years of owning S-Chassis Nissans. Thanks for the advice. I'm not close to buying just yet. I'll do more reading.
Human_Kal (01-02-2017)
Yeah, it's my car. And yes, 18 x 9.5 +40 with 265/35. I have to do a lot of interstate driving, so I needed the combo to work well in all situations. I think the limit, for what I like (super wide tires), will be 18 x 10 +45 with 275's, but the car is my daily, so I really couldn't try it out.
Hi All,
Thanks!
Thanks!
i'm running close to what you're looking for - my set up 18x10 +25, with 245/40 tires Achilles ATR sports - i know you mentioned 18 x 9.5 - so i'm .5 wider
![](https://c7.staticflickr.com/6/5522/30699320310_16e55c4755_b.jpg)
IMG_2853 by Matt Werson, on Flickr
![](https://c2.staticflickr.com/6/5665/30478766761_e2acd6755e_b.jpg)
IMG_2789 by Matt Werson, on Flickr
Still love the Photos Visual
I am on BC Coils - don't remember the exact drop amount but measured from ground to fender lip i'm 24" in front, and 24.5" in rear - I rolled my fronts flat, rolled the rears almost flat, and slightly pulled at each corner - also shaved the fender tab in the fronts (was eating away at the outer sidewall) i probably won't go under 10" wide on the wheels ever again - i get a slight poke and overall a more aggressive set up. I am running natural camber -1.6 in front, -2.4 in the rear, which is nothing, i just keep my toe in check at zero, no camber kits installed yet.
![Name: Tilly12_zps9zifltbd.jpg
Size: 156.9 KB](https://acurazine.com/forums/attachments/3g-tl-tires-wheels-suspension-97/57393d1501309556-wheel-fitment-sticky-tilly12_zps9zifltbd.jpg)
![Name: Tilly13_zpsce9tqisv.jpg
Size: 154.4 KB](https://acurazine.com/forums/attachments/3g-tl-tires-wheels-suspension-97/57394d1501309556-wheel-fitment-sticky-tilly13_zpsce9tqisv.jpg)
![Name: Tilly15_zpsvxgg9cou.jpg
Size: 305.8 KB](https://acurazine.com/forums/attachments/3g-tl-tires-wheels-suspension-97/57395d1501309556-wheel-fitment-sticky-tilly15_zpsvxgg9cou.jpg)
255 on a 10 won't be a stretch - consdering 255mm = 10.04" give or take. So unless your tires run small - you shouldn't see a stretch - i have 245 on a 10 and not really a stretch at all - with 245mm = 9.6" +/-
No staggered, all the same.
I was going to go custom Forgeline.
![](https://c2.staticflickr.com/6/5782/30640302663_8ed697d30f_o.png)
Winter. by Andrew Thompson, on Flickr
I'm not sure the drop, I just dropped it as far as I could being able to still get out of my driveway.
Any time man! I'm thinking something ultra dark for your car.
![Rock On](https://acurazine.com/forums/images/smilies/rockon.gif)
VisualEchos (01-02-2017)
We will see. I'm still debating if I should get it or not. But I am running a 35 series and not a 40 like yours.
These are all nice setups. Again, thanks for sharing your specs. I'm not close to buying anything just yet, just wanting to really know where I'm headed with the project (helps to really visualize it).
Not really a great picture to post lol - but the area where the bumper meets the fender - next to where the screw ties in - there is extra material there, shave/grind it away - i used my dremel on it
![](https://c3.staticflickr.com/1/329/31210775794_9ea9618c80_b.jpg)
tab by Matt Werson, on Flickr
it was eating into the outer sidewall of the tire - i ran the tires like this for almost a 8 months before i moved to my next set - but that effing tab chewed them up - so it you plan to go low (flush) and you are 9" or wider you will most likely need to shave the tab - and yes, since I rolled flat in front, i have no fender liners either![Boogie](https://acurazine.com/forums/images/smilies/boogie.gif)
![](https://c3.staticflickr.com/1/704/31676659250_5a030ff7ac_b.jpg)
tire shred by Matt Werson, on Flickr
My tires have a few cuts in them like that, so I still need to remove the tab. Thanks for the pix.
Boosejars (01-03-2017)
Either way they are still expensive. I'm looking at like $1k wheels and hurting. But we will see. I've been looking into some wheels by Gram Lights and WedSport. I am still a long way from buying though.
I don't consider them to be expensive at all, but I guess it's all about your reference point, I know guys with $20,000 in their custom wheels. I did purchase a set of $2200 wheels for the Lotus, but they listed for $3600, so I got a smokin' deal, and will get all of my $2200 back upon sale of the car (at some point). I keep things super nice, so if I can get $1200 back on a $1700 set of wheels, they really only cost me $500. Divided out by the number of months I use them, they really aren't too bad.
I know what you mean. It's really on who's reference point you are going off of. Since I'm a cheap skate that's why it's so expensive for me. But eventually I want to get a nice set of wheels. But these wheels and tires will do for the time being. I'm not in a rush to get something different anyway. $20,000 wheels? That's insane. Maybe if it's going on an exotic I would get it. Still crazy to me.
Oh Sickest TL (01-05-2017)
you just got to start out where you can...yeah I rocked the xxrs - for almost 3 years i think i paid $520 for the set - no problems, no issues, then I moved to Varrstoen bought this set for $700 - then I sold the XXRs with Tires and used that help cover cost on the new wheels/tires - but these Varrstoens have been doing good so far had them on the car for about a year can't complain. little steps - until you can get to where you want to be - a wife, 2 kids, 2 dogs, 3 cats, a house - i can't go all out on wheels lmao - but in stages it works.
![Thud!](https://acurazine.com/forums/images/smilies/thud.gif)
justnspace (01-12-2017)
3 Cats
3 Kids
3 Cars
3 Sets of wheels for the Exige (including some XXR's)
3 Sets of wheels for the TL
I suppose I wouldn't mind having 3 wives, and 3 houses, but damn that expense.
Man, I don't even have a mortgage. Just a wife and kid. But I also live in California where rent is out the roof. These ballers in here with all these things and can still spend on toys. Must be nice. But that probably means you guys have education as well which allows you to have a job that can afford all these things. I've eventually going to get some wheels that are around $1400-$1800. Just not in a rush right now. Plus this TL is giving me issues. But not the cars fault. It's just an old car.
