What spacers should I use?
I need help with this one, I already have everything purchased. Rims,tires, shocks, and springs. All I'm missing is some spacers for my rims. They're 19x8 + 38 offset all around . I want my tires to stick out a lil bit out of the fender. What size spacers should I buy to accomplish this? I want to buy everything so I can put it all at once. Any help is apreciated. Thanks.
BANNED
what size tires? if they're 235/245 you can probably put 10mm spacers all the way around...but it also depends on a few other things.
do you have brembos/bbk?
what kind of wheels? face design?
http://yfrog.com/h2vfxfqij
BANNED
good deal.
10mm spacers all around will put you at a +28 offset, which will be pretty flush to the fenders. you could maybe squeeze a 15mm in there but if it were me, i would just go with 10's
BANNED
my wheels are 19x8 up front w/ a +30 offset and they are not 100% flush (close)...yours will be +28...so yes.
hub adapters and wheel spacers?
the ichibaV2 wheel spacers come with hubcentric rings and pressed in extended studs. what do you need hub adaptors for?
Hubcentric rings are only to bring the center hub/bore size down to Acura/Honda's size.....64.1. I believe that's the size for our vehicles.
And yes you will be able to use the spacers with the rings. I will be doing the same shortly.
BANNED
^ahh...good call. i forgot about that. the ichibas with the rings are 15mm and above, correct?
I found these on eBay. What do you guys think?
http://cgi.ebay.com/ebaymotors/ICHIB...Q5fAccessories
rockvilleTL
09-19-2015 04:44 PM
