TPMS sensor replacement
Old Nov 13, 2012 | 06:41 PM
lsantana954's Avatar
ok so i had a blow out couple weeks back and the sensor was damaged. I finally got around to ordering a new one so now im curious as to the actual procedure once it has been replaced. How is it activated? Does the mechanic have to hook anything to program it to the car or is it one of those things that once you start driving the car will "learn" it? Just want to know whats involved so the local shops dont try to feed my any BS
Old Nov 13, 2012 | 07:10 PM
makk's Avatar
It must be registered to the vehicle. Any shop with a tpms diagnostic tool can program it. Most reputable tire shops should have one.
Old Nov 13, 2012 | 07:36 PM
rhafikjaan's Avatar
Buy an oem sensor. Make sure they install it correct. It needs to be tighten from both directions if left loose it can vibrate in wheel.
Install on wheel.
Put wheel on car.
PSI will show around 58 psi.
Few miles later actual psi will show.
No need for tpms tool or w.e was mentioned above.
Car will pick up new sensor automatically
Old Nov 13, 2012 | 07:51 PM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
^+1 Agreed. If they are OEM, they will synch up in a couple of miles.
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
bailey24
Nov 21, 2015 08:43 PM
lland
Oct 4, 2015 04:47 PM
darknite123
Integra
Aug 30, 2015 03:00 PM
