TPMS question
Old 02-04-2007, 08:58 PM
sixsixfour's Avatar
TPMS question
If you mount new wheels and tires without the sensor(s) onto a TPMS-equipped TL, would the car freak out? Im just curious.
Old 02-04-2007, 10:46 PM
sunnyflava99's Avatar
The TPMS light stays on and the display will say TPMS error. Other than that no big deal.
Old 02-04-2007, 10:50 PM
road_boy's Avatar
Yea i bought wheels and totally forgot about the TPMS sensors...I ran the car w.out them for about 2 months and that TPMS error would come the MID and u just push the reset button and it just shows a "TPMS" error on the dash...When i switched back everything was normal. . . However i must say it grew to be really annoying!
Old 02-05-2007, 10:01 AM
sixsixfour's Avatar
thanks guys!
Old 02-09-2007, 05:54 PM
juruki's Avatar
Can you install these TPMS sensors on aftermarket wheels???
Old 02-10-2007, 05:58 PM
road_boy's Avatar
yea i think you can, they just have to change the valve stem of the new tire with that of the stock set.
Old 02-10-2007, 07:24 PM
avs007's Avatar
Actually, it's not that simple. It depends on the wheel design. If you notice the standard TL wheels look different between 05 and 06 when the sensors are added. It's to clear the sensors...
Very few aftermarket rims will have adequate clearance for the sensors, unfortunately. (I found that out, when shopping for rims )
At least this is the case with the nicer rims anyways. You have to ask the wheel-shop if it will clear the sensors. It depends on the design of the wheel where the stem would go. In my case, almost none of the Volk and Work wheels fit the sensors.
Old 02-10-2007, 10:19 PM
limited's Avatar
Strap them in. I know HRE provides bands to strap the TPMS in. You can may your own as well:
http://www.350zforum.com/net/viewmsg...l&msg_id=81287
350Zforum.com
Old 02-11-2007, 06:27 PM
Hey Now!
Mr. Hill's Avatar
RonJon wheels are can be used with the TPMS sensors.
navtool.com
3G MDX (2014-2020)
32
01-20-2016 11:43 AM
navtool.com
31
11-16-2015 08:30 PM
johnalfa
11-05-2015 06:44 PM
RobbDizzle
10-15-2015 11:16 AM
Quick Reply: TPMS question
