Tpms
Sure you can, there's an aftermarket TPMS system you can add to any car, it comes with a basic display unit (looks like a radar detector) and an advanced display you can mount anywhere you like.
Here's the link:
http://www.vulcantire.com/smartire_disp.htm
You can't add the factory one though.
Here's the link:
Originally Posted by DMZ
Why not if you order all the appropriate parts?
Originally Posted by stevel
would be silly to try. you would have to build or modify wiring harnesses and buy many updated parts and hope they are compatible with other systems on the car. example.... instument cluster will probably not have the software in it to display any tire pressure warnings. I would immagine that would be expensive if even possible to change to a later cluster due to software version changes within other control units that it must communicate with on the car. not to mention most cars have a tire pressure monitoring control unit. how are you going to wire that into a car that it wasn't made for???
Do a search here in the forum. I got a list of all the parts needed, somewhere around $500-$600. I think communication from the wheels is wireless. The only unanswered question is the software. Still, I doubt I'd try to do it myself.
I think there is a wireless receiver near each tire. There is no programing involved, so that is the only way it would be possible. If there was just one receiver, how would it know which tire is F/R or F/L.
Personally I think you're better off just buying a new car if you want TPMS that bad.
neuronbob
23
Jul 16, 2019 10:48 AM
