TL Rim Weight
with tire mounted it is around 55 pounds, not sure without the tire.
My wheels and tires weighs in at 48 lbs each.
The tires are Potenza G 009's in a 235/45 HR17 and according to tirerack they weigh in at 25 lbs.
The tires only had a couple hundred miles on them when I weighed the wheels so I'd bet the wheel weighs 23-24 lbs.
Hey, you stole my answer. I take it things are good with them?
'06 750Li Sapphire/Creme
Originally Posted by ndabunka
Sorry but there is no way the stock 17" OEM rim and tire combo weighs that much! My 19" rims and a fairly heavy tire weigh in at 53lbs TOTAL. My aftermarket 17's with worn out tires came in at either 50lbs or 51lbs. At one time I thought my OEM's were over 50lbs but I later learned that my aftermarket 17's were heavier (by about a pound) than my OEM's
I just shipped my rims and tires to him. Each box weighed 55 lbs.
^^Sorry to hear that. Shouldn't they had covered under warranty? How old is yours?
Those came off in Oct and they set in my living room until I shipped them to you.
