Tire Rub?
Tire Rub?
I have a 2005 TL and I'm getting new rims sepcs:
Size -18"x8"
Bolt Pattern - 5x114.3
Offset - +40mm
They come with 235/40/18
Will these fit fine? Or will they Rub??
Any help would be great!!! Thanks!!
Size -18"x8"
Offset - +40mm
Take a look at the tire to fender height and see how far the car needs to drop to be even with the widest part of the tire, maybe 3", so if you loaded up the trunk with a 1000 lbs you might have a problem, just a wild guess. Also if you look at the tire specs, you'll see that certain 235/40-18 tires are wider than a 245/40-18. Sounds crazy but the larger size doesn't always indicate a larger width tire, although it should.
Just wanted to add, don't know what size tire is on the car now, but if stock wheel/tire, take a momemt and loosen the lugs and move the wheel out 1/4" and see where it sits. This will be where the new wheels reside, actually only.20", but you'll get an idea.
rockvilleTL
Sep 19, 2015 04:44 PM
oyayjoe
Sep 12, 2015 04:40 PM
DunesCreations
Sep 9, 2015 12:03 PM
