TIRE RACK Question...
Old Aug 8, 2001 | 01:04 PM
lilboykorea's Avatar
At tire rack... if i try putting on a 18inch on the TL-S... the recommended tires are 225/45... why 45? shouldnt it be 40?
if i do put on 45 will it be rubiing? if it doesnt rub it'll be a good way to reduce the wheel gap with out lowering..........???
Old Aug 8, 2001 | 02:31 PM
fahoumh's Avatar
Shogun Assassin
They recommend 45's probably because it'll have (almost) the same overall diameter as the original tire-wheel combo. If you get 40's, the diameter will be smaller which have a smaller circumference of the wheel, and then your speedometer will be inaccurate because it's guaged to the original set.
Old Aug 8, 2001 | 02:32 PM
fahoumh's Avatar
Shogun Assassin
....also, if the wheels have a high enough offset, they shouldn't rub....go to the FAQ for info on TL offset
Old Aug 8, 2001 | 02:37 PM
99WDP's Avatar
The 225/40 tires are a closer match to the diameter of the stock TL-S tires. 215/45-18 are actually the closest. With either of the 45 series tires the selection is very limited, I would recommend the Michelin Pilot Sport if you decide to go that way. I know one of the members (can't remember who) has the 225/45 and says the only rubbing is when the wheels are turned all the way and he hits a dip in the road.
Old Aug 8, 2001 | 06:13 PM
adamyankee's Avatar
I have mentioned this before and I don't understand Tire-Rack.
Each stock tire has something called plus sizing.
Basically, it's the next biggest setup which gives you the closest diameter to stock without going bigger.
Like this.
Stock - 205/60-16 - 25.69 dia.
Plus 1 - 215/50-17 - 25.46 dia.
Plus 2 - 225/40-18 - 25.08 dia.
The 225/45-18 is closer but it is bigger so it should not be recommended.
Yikes
May 3, 2021 04:29 PM
CaliBud916
Sep 19, 2015 01:56 PM
FC2012RDX
1G RDX (2007-2012)
Sep 4, 2015 02:05 PM
fallacy
Sep 4, 2015 10:15 AM
Snafunk
1/2G MDX (2001-2013)
Sep 3, 2015 08:01 PM
