Tire Inflation Specs for ASPEC 3rd Gen TL
Photoshops, and Polls!!!!
List what the tire inflation should be for these wheels
ASPEC WHEELS
What kind of Tire
Front
Back
Automatic or Manual Transmission
Does anyone know what these Yokohama's should be inflated at
ASPEC WHEELS
What kind of Tire
Front
Back
Originally Posted by cTLgo
Check zee label in your driver's side door jam. I believe it is 35 front, 32 rear, but don't hold me to that.
that would probally hold true for stock wheels, but the aspec wheels are different!
Originally Posted by Lore
39 Front and 36 Rear, per A-Spec wheels sticker. It's the same for both MT and AT. Doesn't matter what the tires are.
wow im underinflated!!!
Well, if you got the A-spec wheels installed at a dealer, per the install instructions, they are suppose to change the label
good point, unfortunatly i bought them off the internet from falconi of acura (good experience fyi)
Overlord - Team Abyss
What do y'all think about running the standard 17" rims with some Michelin Pilot Sport A/S tires on them at the A-Spec pressures? Is the pressure increase due to the larger rim diameter or what? I know my stock tires only lasted me 25,000 miles at stock inflation pressure which I monitored carefully. Tires are too expensive to have to replace every 25,000 miles so I'm wondering if uping the inflation pressure might help me out in the mileage department.
Any thoughts?
Any thoughts?
What about 245/40/18?
Would you think the recommended inflation psi's would be any different if running a slightly wider tire than the 235/40/18's? My guess is that the 39 psi (for fronts) and 36 psi (for rears) would still be the recommended pressures for 245/40/18-sized tires.
Does anyone advise differently?
CEO, Team Anthracite
Originally Posted by Weekendzs
I keep hearing good things about Falconi Acura. You mind me asking how much they run you ?
2000 for wheels and tires balanced and shipped on a pallette
(maybe a little bit more)
1fatcrxnem1
22
06-01-2018 01:23 AM
DiamondJoeQuimby
09-10-2015 11:40 AM
nuldabz
09-03-2015 05:49 PM
