Tein SS user come in!!! NEED HELP
Old Aug 13, 2010 | 06:15 PM
jray906's Avatar
Unhappy Tein SS user come in!!! NEED HELP
I had a problem with the Tein SS suspenion. Is it normal when every time I go through a dip or high bump in the road that the suspension has a really loud noise which sounds like it has reached top? It sounds like the suspension hitting my car.
Old Aug 14, 2010 | 12:07 AM
AMUA6's Avatar
ScoobyZINE
Seems like I've read a thread with a similar problem.. But I think after months of use it never was figured out Try searching
Old Aug 14, 2010 | 12:49 AM
gotkilled's Avatar
NBP is a pain...
Try stiffening up the suspension. Were all the parts from the top hat assembly from the stock shocks transferred to the SS suspension?
Old Aug 19, 2010 | 04:12 AM
jray906's Avatar
Just came back from my trip....
I am not sure, becoz installed that in a auto shop. And I tried to stiffening up the suspension but the problem is still there. Anyway thanks for you respond.
Old Aug 19, 2010 | 04:45 AM
PowerCommander's Avatar
hmn... yet another issue with the tein ss. I've read in other forums and reviews that the damper goes bad fairly easy along with corrosion issues with that coilovers. I had considered getting the tein ss coilovers but it seems the more I do research the more i'm discouraged from it. Still sticking with the eibach or ksport coilovers for now i suppose. Do you have experience with ksport and eibach pros?
Old Aug 19, 2010 | 08:52 AM
killersrt's Avatar
Try pushing down on each corner of the car and see if you hear any unusual noises. Notice any fluids coming from the shock body? Did you buy them new? Just like regular shocks, coilovers can also blow out and go bad.
Old Aug 20, 2010 | 12:45 AM
jray906's Avatar
I don't have experience with the ksport.....but I know eibach spring is pretty good...
I bought them new from a local auto shop. I think I cant hear any noises if I only use my hand to push down on any corner. I can only hear a huge noise when I go though a deep hole or high bump.....like the spring compress to the highest point of the coilover and hitting the car frame, which sounds like so horrible....
Old Aug 20, 2010 | 01:08 AM
AMUA6's Avatar
ScoobyZINE
Is everything tightened up? Did you tighten up your RSB? Is it coming from the front or rear of the car?
Old Aug 20, 2010 | 01:20 AM
jray906's Avatar
Front both right and left. Do you think the auto shop stole something inside my suspension system?
Old Aug 20, 2010 | 09:57 AM
InFaMouSLink's Avatar
Chapter Leader (NY/NJ)
installed incorrectly probably
Old Aug 20, 2010 | 08:21 PM
jray906's Avatar
It is so hard to say, normal bump and deep is fine.....but serious one is making noise coming out.....Just like the spring hitting the car....
Old Aug 20, 2010 | 09:34 PM
odishaw's Avatar
possibly they didnt tighten the upper bolts enough on the tower. or they've come loose. my girlfriend has basics in her rsx and they bolts supplied came loose we had to throw another one on top of it so it couldn't un-thread itself. otherwise the shop did not assemble them correctly.
Old Aug 20, 2010 | 10:49 PM
Matt HKD's Avatar
I had a problem similar to this on mine when i hit some really bad rail roads going like 30. I felt like the car bottomed out. Just slowed down next time and I have no problems now
Old Aug 22, 2010 | 12:25 AM
jray906's Avatar
I am not sure about that too. I last suspension system is Koni yellow and had the same problem too. Normal bump is fine but not the deep rail....
Yes, slow down then the problem is gone...but sometime u just can not stop or slow before you hit the deep rail....
So I think there is not solution to fix it? Any professional guy can give us any suggestion?
Old Aug 24, 2010 | 08:45 PM
BMT62688's Avatar
not sure if it would be the same problem i was having but a lil after i installed coilovers i was getting a loud noise like you are talking about and it ended up being my motor mounts were bad i guess the stiffer suspension made it vibrate more when i hit bigger bumps but try checking the mount were the belt is that one seemed to be the worst for me
Old Sep 15, 2010 | 03:39 AM
jwr0ng626's Avatar
did u get it fixed yet?
is it in the front or rear? or both? I helped my friend install coils on a si sedan and we forgot to put the rubber .... spacer(?) in the rear and it kept knocking over bumps.
Old Sep 15, 2010 | 10:58 AM
murph145's Avatar
ahhh so glad i got megans
Old Sep 15, 2010 | 12:12 PM
BoxOn20s's Avatar
I had a similar issue but found it was the passenger side motor mount. A friend of mine who works at an Acura dealership said by the looks of it there was a high possibility that the mount was initially damaged when the powers steering hose recall was done and simply got worse over time. Apparently some techs forget to disconnect the mount from the motor when they lift the motor to gain access to the hose. I have Tein SS all the way down and have had no problems since replacing the mount.
Old Sep 15, 2010 | 12:27 PM
myron's Avatar
I had this happen to me too after my suspension install but I replaced the tie rods in the back ( I think they are called sway bar tie rods) and the noise went away. That could also be the problem
Old Sep 15, 2010 | 04:53 PM
RjG2's Avatar
How low are you? Any car that is very low will bottom out on certain bumps or dips in the road. Tein ss like any coil over has very short shocks and springs ( compared to the stock ones) which means there is very little travel when hitting large bumps. You may have them set way too soft. Remember these things are technically meant to only be used for racing ( smooth roads with no bumps). Ive had my ss for a little over a week now and have only bottomed out twice but it was unavoidable.
calrow
May 3, 2017 10:21 PM
InFaMouSLink
Nov 11, 2015 12:19 PM
SinCityTLX
55
Oct 11, 2015 01:20 AM
AcuraKidd
Sep 25, 2015 11:18 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
