Safe off set
Definition of vague:
–adjective, va·guer, va·guest.
1. not clearly or explicitly stated or expressed: vague promises.
2. indefinite or indistinct in nature or character, as ideas or feelings: a vague premonition of disaster.
3. not clear or distinct to the sight or any other sense; perceptible or recognizable only in an indefinite way: vague shapes in the dark; vague murmurs behind a door.
4. not definitely established, determined, confirmed, or known; uncertain: a vague rumor; The date of his birth is vague.
5. (of persons) not clear or definite in thought, understanding, or expression: vague about his motives; a vague person.
6. (of the eyes, expression, etc.) showing lack of clear perception or understanding: a vague stare.
Gotta help us help you man. We need more than that to say anything about offset.
Are you just looking for wheels with correct size tires with no fender mods and that won't rub?
Or something that will get as close to the fender as possible, no fender mod, fitted tires but still no rub
Or wheels flush with fender, fender roll/cut, and stretch tires?
are you keeping the 04 wheels and want to make them fit?
you can buy spacers (check ichiba or akata) to push the wheels away from the calipers so they'll fit
see how much space you'll need in order to clear the calipers and pick your spacer (I think max that akata makes is 25 mm)
also, get the spacers with pressed lug bolts in them so you don't need to worry about being too short
DementiaPhuro
Sep 29, 2015 05:31 PM
4drviper
Sep 23, 2015 07:42 PM
