"Rusty" wheels. Need some pointers...
Old May 20, 2010 | 07:07 AM
gilla_monster's Avatar
I have a problem that some of you might have encountered, although I searched and couldn't find anything about it...
I just installed a set of Ronjon 18" Liquid Graphite Legends on my NBP. (Looks amazing IMO). However, between the holes in the wheels for the lugs, there are 5 tiny holes that go all the way through to the back of the wheel. I'm not even sure what they are for... When water sits in these holes, it rusts the center part of the rotor and then spins rusty water all over my wheels. Annoying! I'm looking for a solution. Possibilities are:
  • shiny, new rotors (too much $ right now, not happening)
  • Paint the center of the rotor to keep it from rusting
  • purchase a wafer-thin wheel spacer to provide a barrier on the inside (I have no idea what to call it to search for it, but I KNOW i saw one somewhere, ebay maybe)
  • Put tape on the back of each hole.
  • Put some sort of perfectly sized rubber plug x20 to keep water from getting in there. (i'll need a bit of help with that one, plus without knowing what the small holes are for, I don't want to mess with their intended purpose.
If anyone had a similar problem, or has seen anyone try to fix this, chime in. I love washing my car, but even cleaning the wheels every day doesn't help because it is impossible to dry the water out of those holes, so unless I let it sit untill it air dries, the problems starts all over again.
Old May 20, 2010 | 07:32 AM
Turbonut's Avatar
Plug the holes on the back side with silicone.
Old May 20, 2010 | 08:47 AM
Jesstzn's Avatar
^^^^^ yeep .. been covered before ... remove the wheels and put some clear silicone in each hole from behind. This will prevent water from entering the holes from the front when washing etc and rusting the hat.
What I did with mine was fabricate a small rubber stopper that went in 1/4" then filled the holes from behind up to the stopper . Installed the wheels and let the silicone set then pulled the stoppers a few hours later.
Old May 20, 2010 | 10:11 AM
svande02's Avatar
just got an 06 black tl. Gimme some suggestions!!
Old May 20, 2010 | 03:10 PM
does anyone know what those wafer thin "spacer" disks are called?
Old May 20, 2010 | 04:40 PM
Turbonut's Avatar
???? Are you asking about the dust shields that install behind the wheel?
Old May 20, 2010 | 05:43 PM
Slpr04UA6's Avatar
-------Tim-------
Spacer's? Or like Turbonut said, brake dust shield's! ???
Old May 20, 2010 | 09:02 PM
these were flexible (i think) gasket-like insert that fit on the lugs and protect the back of the wheel. They have the same profile as a spacer but are super thin and would solve the problem of the water getting to the hat beneath and rusting.
I can't figure out what to call them to to a search. I've tried EVERYTHING.
Old May 20, 2010 | 10:46 PM
BlueAc's Avatar
Acura drove me away too..
Here's one... Don't be a
Old May 20, 2010 | 10:59 PM
AMUA6's Avatar
ScoobyZINE
This sounds crazy but you can also take a cereal box and cut it out to fit between the wheel and rotor. We used to use cereal boxes all the time in the woods as hub gaskets etc back in my 4 wheelin days. BUT, do it right the first time lol Silicone!
Old May 21, 2010 | 09:21 AM
CORUPT's Avatar
causing mischief & mayham
I just did some silicone the other day
Old May 21, 2010 | 04:10 PM
KzooTL's Avatar
05' AT SSM
Not sure i understand, the rust is coming from the rotor?
The top hat on my rotor is rusted and the back of my rim where it mounts is also rusted. I just sanded them down primer and painted...no more rust 12 bucks worth of paint and sandpaper.
Old May 21, 2010 | 11:15 PM
^ That is probably what I will end up doing. Silicone might also work, put it's really just masking the problem. if I can get the hats to stop rusting, I won't need silicone.
Old May 22, 2010 | 06:05 AM
Turbonut's Avatar
It's not just the hats, it anything that can rust will, e.g. the rotor itself and the studs. The Acura resides in a heated garage, but my daughter's car and on occasion one of my other cars may sit outside overnight and when you go out in the morning, the rotor surface has a rust film that has developed. Add a little moisture and during the first brake application there is rusty moisture beige slung around behind the wheel.
Old Jun 8, 2010 | 10:19 PM
I found them!!! I was looking through a Baviarian Autosport catalog for my buddy's 335i and found the product I was looking for.
Wheel Mates
If you were looking for something like this, here is the link to purchase: 4505
vpasla1
Sep 17, 2016 07:24 PM
jsonkimz
Mar 28, 2016 07:49 PM
Chojun
Dec 16, 2015 07:12 PM
RobbDizzle
Oct 15, 2015 11:16 AM
Sep 17, 2015 09:01 PM
