rubbing issues
rubbing issues
so i got the neuspeed supercup kit installed yesterday and set on lowest perch and i have +35 offset wheels and im rubbing on the front.....i noticed the fronts seem to be already a little "rolled" is there a solution to this? can i roll them anymore?
kinda dont wanna raise it up...i like the way it sits!
Pics?
It's harder to roll the fenders in the front, cause there isn't a huge lip to roll in the front like the rear.... you could certainly try to roll anything that you can but probably won't help that much. I'd suggest getting a camber kit. You could also see if you can cut out any of the inside fender lining.
94 DC4 RS LSV/Turbo
ok let me help the op out and wead out the INCORRECT info given above...
a camber kit WILL NOT ADD more negative camber IT WILL CORRECT IT
there is a tiny piece of metal on the fender about 4 inches before the fender meets the bumper, that is the spot that is rubbing on your tires...
you can trim it using a dremel... then you'd want to throw a coat of paint on the area you cut off, black works fine...
I am about to roll my front fenders and thought this might be a problem I was going to use a small bead of epoxy along the edge to hold it up..
I would like to hear what others have done for this..
rockvilleTL
Sep 19, 2015 04:44 PM
oyayjoe
Sep 12, 2015 04:40 PM
jmoney2001
Sep 11, 2015 12:07 PM
