Help on Neuspeed Superkit
Old Apr 24, 2009 | 05:00 PM
Tension's Avatar
I'm going to buy the neuspeed superkit with sport spring. My care is TL 06 and i'm not sure if i need need both front and rear camber kit for this set up. Also what is the best setting on the koni shock. Please help!!!! Any suggestion are appreciated.
Old Apr 24, 2009 | 05:01 PM
trojanman10984's Avatar
boost 3G
just installed mine today! i love it even tho its set to full soft at the moment...def put it on the last perch all around..youll love it....you shouldnt need a front camber kit but most likely a rear depending on how low you decide to set the perchs
Old Apr 24, 2009 | 05:50 PM
BAT3STL's Avatar
What kind of drop you're looking for, I use to be on Swift 1.5 all around I thought the sport springs and by setting the konis on the lowest perch was going to be enough but it was not I still have a gap in the rear, other than that they handle great I have thenm set 1.5 turn from soft to stiff.
Where are you located at I'm looking for someone to swap race for my sport springs.
Old Apr 24, 2009 | 06:47 PM
boost 3G
^^^ you still ahve a gap?? how much of a gap? mine is sittin a bit over the tire!
oh and also did you wait to 500 miles every talks about before adjusting the damping?
sorry to hijack your thread!
Old Apr 24, 2009 | 06:50 PM
BAT3STL's Avatar
I'm about 650 miles now and yes I have about 1 full finger gap in the rear, the front is perfect is just the rear that bothers.
You have any pics.
Old Apr 24, 2009 | 07:04 PM
boost 3G
havent taken pics cuz i did it this mornin and at work right now but ill take pics tomorrow after a quik wash! so you waited 500 miles? my front rubs a little on full soft
Old Apr 24, 2009 | 07:14 PM
BAT3STL's Avatar
I didn't have any rubbing, I'm running 18x8.5 what about you.
Old Apr 24, 2009 | 07:21 PM
boost 3G
19x8.5 so thats prob why i dont ahve a gap and you do and thats prob why i rub some places and you dont lol
Old Apr 24, 2009 | 07:23 PM
BAT3STL's Avatar
and that's the reason I'm going with neuspeed race.
sorry for hijacking your thread bro.
Old Apr 24, 2009 | 08:41 PM
Tension's Avatar
Yeah, i just talk to the guy that going to install the suspension for me he said" i need to have the front camber kit but not the rear" so this is really confused me.
Old Apr 24, 2009 | 09:31 PM
boost 3G
i really think hes wrong about that haha i would wait and get the kit put on and than go get an alignment and you will see than that the back will be way off compared to the front...other than that i cant really help you too much about that..but i do know that alot of people jsut run rears and not both
Old Apr 24, 2009 | 10:14 PM
BAT3STL's Avatar
Before I got the neuspeed sport I used to be on swift springs 1.5 all around, when I went to get my alignment they told me I only needed camber in the rear, I think Trojanman is right.
Old Apr 25, 2009 | 11:19 AM
javamanbill's Avatar
J Bill
I recently had the same kit installed. After alignment they were able to bring the toe in perfectly and the camber was just within specs so I'm going without a camber kit. I'm on the 3rd perch with the sport springs.
Old Apr 25, 2009 | 02:27 PM
Tension's Avatar
Do you have pic of your car after the neuspeed installed?
Old Apr 25, 2009 | 08:11 PM
TLheaven's Avatar
Shyne
You don't necessarily need a camber kit at all. Under most circumstances as long as your alignment is good and you toe is close to zero you should not have problems with tire wear.
Old Apr 25, 2009 | 08:50 PM
J Bill
I posted before and after pictures in the following thread:
https://acurazine.com/forums/3g-tl-tires-wheels-suspension-97/neuspeed-kit-before-after-pics-723520/
Old Apr 25, 2009 | 10:22 PM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
set it to soft for the first month... and if you fix the toe you wont require a camber kit... the camber kit is mandatory for the race springs
pm excelerate he'll help you out with any further questions
Old Apr 28, 2009 | 11:04 PM
Tension's Avatar
Thanks for all the advised above and i have just made the purchased with Exelerate hope it come out nice. Also why do i need to set it soft for the first month? do you mean i must adjust the shock after the first month? and is it hard to adjust the shock?
Old Apr 28, 2009 | 11:08 PM
boost 3G
its to get the full life out of your shocks
to adjust is really easy...you should have gotten a "knob" with your kit...its white...you can see under your hood where you can place that knob and twist to stiffen them up...and for the rears youll have to take out the rear seat (super easy) and you can see on each side under the hat rack where you can place the knob and twist to stiffen
hope taht helps
Jul 16, 2017 07:33 AM
DUECE_DXJ
Sep 7, 2015 06:40 AM
jlspeed29
Dec 17, 2004 02:59 AM
SicK TypeS
Jul 23, 2003 12:09 AM
