Rims!!!!!!!!!!!
Rims!!!!!!!!!!!
Hey people! I have got a question for you TL experts. I had a 96 Maxima and have konig verdicts rims 17 x 8(5-100/114 40 O) with dunlop sport 5000 235/45/17 . Can this rim and tire combo fit on my 2003 TL-S without any rubbing or problems???? Anyone have any suggestions for me? Is it true about TL & CL transmission? I heard bad things!!!!! Hopefully it's just a rumor. Thanks
...and then there was One
8 inch rim with a +40 offset (that's what you meant, right), with 235 tires probably won't even fit without rubbing even if it's not lowered.
Maybe you can trade someone straight across.
As for the trannies, don't worry about it. If it happens, it happens, and you have a warranty. It's not a big enough problem for a recall, so that should ease 'some' worries. If there is any sign, though, take it to the dealer and have them replace it for safety reasons, though.
I shoot people
Yeah... your TL-S deserves better wheels anyway.... (No offense to anyone out there with Konig wheels)
....and as for trannies go... I'm on my 5th one!!! No, I'm totally kiddin' (knock on wood)
Originally posted by TL_99
the rims i am looking at r 7.5" wide,
they will rub i tried it with my buddys maxima rims same offset and size tire. stuck out of the wheelwell way too much
Hmmmm...... i kinda confuse here. i spoke with a few people and one had a cl with 17 x 8 and 235 45 17 tires and he said it fit no problem and the other guy has a tls and he has the same size tire and rims. good fit as well. then i read a post and someone said that 235 45 17 tires will fit on our stock tls rims. any input is great appreciated!
Moderator Alumnus
According to every tire manufacturer 235/45-17 will fit on wheel widths of 7.5" - 9". With the TL-S wheel width at 6.5" that would rule out going with 235's. Although others have mounted 235's on their TL-S wheels, I would recommend otherwise.
More important than the width of the tire would be the offset of the wheel that would determine whether or not rubbing will occur. When purchasing your wheel just keep in mind that the stock offset if +55.
