Replacing entire control arms or just bushings only?
Hello AZ members.
My car got a quick inspection by a third party potential buyer's mechanic and the mechanic left a message that the control arms seem to be bad and need to be replaced.
I'm not sure which control arms he meant.
Could you let me know what the common control arms that need to be replaced in general? Mine is a 2005 with about 83k miles or near 138k km manual trans.
I tried looking for the parts price and the entire front and rear control arms replacement seem to be costing too much at this moment.
So I was thinking if changing brushings only would be fine as well?
So far I am not experiencing any symptoms but since I just changed my tie rods (DIY), the wheel alignment service needs to be done but
I heard that I must do wheel alignment service after changing control arms so I'm gonna do it once I figure out what to do finally.
Could someone please answer me? which control arms need to be replaced?(whole?(front & rear?) or brushings only?)
Thank you
Thank you
Usually, its the front lowers. The compliance bushing goes bad.
If you've got access to a press, buy some Honda OEM bushings.
Aftermarket control arms on rockauto should be cheap. They won't last or function like a factory part. But they're cheap...and they work.
Hello AZ members.
Thank you
Thank you
Maybe ask the mechanic for more details. I just realized you're selling the car so I would probably just replace compliance bushings and be done, I'm sure the others are fine
Hello all, I too am forced to DIY both Front LCAs due to cost. Getting labor quotes (I buy my own parts) just to press out and press in the compliance bushings is almost as expensive to replace the whole arm...the argument is you have to remove the arm from the frame anyway to do the work, so why not replace the arm.
Anyway, my question is when removing the LCA, is there any pressure or other parts of the steering assembly that fall or become unaligned? Thanks in advanced.
jegan (08-17-2020)
Thank you for your sharing.
Do you also happen to know if I could use 2006gen Accord's bushings? Are those compatible? Looks wise it seems to be the same but parts number seems to be slightly different? (Rockauto)
Are these the right parts?
Could I know which brushings I need to buy??
It says
-Front Lower Outer
-Front Lower Outer Forward
-Rear
-Rear at Knuckle
I heard there are 3 bushings but no idea which ones to choose.
Please help.
Thank you
Oh wait...do you have some agreement with the new owner that you're just gonna supply the necessary bushings to his mechanic?
You clever devil.
That poor mechanic.
Why are you looking at rear knuckle bushings?
You clever devil.
That poor mechanic.
front lower its ABOUT 4" IN DIAMETER the mevotech supreme is the right one....but buy acura ones for like $28 each they last longer than the mevotech ones by a longshot.
RoadRover
25
05-29-2016 11:20 PM
