Rear tie rod torque spec for the camber kit?
Rich
Ordered rear camber kit from heeltoe. Anyone know what’s the torque spec for the upper rear tie rod?
Same as the factory bolt. Something like 50LB-FT for the bolt that goes to the subframe (make sure you wait until the suspension is at ride height before you tighten this one!).
And something like 35LB-FT for the ball joint castle nut.
Rich
^^^ thank you. Changed the front struts today. Went to get alignment and find out the right rear camber is way off -1.8. Getting camber kit for that side. Left one is good, right on the money.
stewie20068
1G TSX Problems & Fixes
01-20-2013 01:59 PM
