Rear tie rod torque spec for the camber kit?
Ordered rear camber kit from heeltoe. Anyone know what’s the torque spec for the upper rear tie rod?
https://cimg6.ibsrv.net/gimg/acurazi...3460bedb2b.png |
Same as the factory bolt. Something like 50LB-FT for the bolt that goes to the subframe (make sure you wait until the suspension is at ride height before you tighten this one!).
And something like 35LB-FT for the ball joint castle nut. |
^^^ thank you. Changed the front struts today. Went to get alignment and find out the right rear camber is way off -1.8. Getting camber kit for that side. Left one is good, right on the money.
