Re-torque
Old Mar 8, 2005 | 11:49 PM
6mtV6's Avatar
I6
Re-torque
Did anyone re-torque their aftermarket wheels after the first 50-100 miles?
Old Mar 15, 2005 | 08:26 PM
AsianTL's Avatar
Asian07RL
I did and set at 80 ft-lbs
Old Mar 15, 2005 | 09:42 PM
6mtV6's Avatar
I6
I re-torqued it and 1 or 2 lug nuts on each wheel was loose.
I guess it is a good idea to re-torque after the first 50-100 miles.
Old Mar 16, 2005 | 10:13 AM
cM3go's Avatar
definetly good practice to retorque the wheels
Old Mar 16, 2005 | 02:45 PM
SKIUL8R's Avatar
Team Nighthawk Member
They definately do loosen up. If you do them yourself be sure to be careful not to break your KEY... Most wheel places don't torque the locking lug nut down as tight because they know how fragile they can be.
I'm not sure this is good or bad practice, but seems to be true at the places I haunt.
Old Mar 16, 2005 | 03:22 PM
what exactly is re-torque?
is it just to tighten up the lug nuts once in a while? or maybe after people put on rims?
Old Mar 16, 2005 | 04:08 PM
6mtV6's Avatar
I6
When you first put your aftermarket wheels on or if you just rotated your tires you have to torque them to 80lbs. After 50-100 miles you should re-torque them because they will get settled in and the lug nuts might become loose.
This should be done whenever you take your wheels off.
Old Mar 16, 2005 | 04:25 PM
how do u know how much is 80lbs or 70lbs?
whenever i had to take off the wheels on any cars, i would tighten them completely...
Old Mar 16, 2005 | 05:15 PM
6mtV6's Avatar
I6
You would need to use a torque wrench. You can adjust it to a certain lbs and when it reaches the lbs it will click.
If you didn't torque the lug nuts on your TL to the correct lbs, I would suggest you go buy a torque wrench and tighten it to the correct lbs immediately.
hobbestec
Apr 13, 2008 09:07 PM
uncming
May 27, 2003 07:43 PM
TLTypeS
Sep 18, 2001 11:50 AM
Mythos
Sep 8, 2001 02:25 AM
EricL
Feb 17, 2001 07:34 AM
