raked look 17's in front and 18's in back
I'm thinking of getting konig images and I kinda like the raked look of my tl with the comptech springs and I was thinking of going with 17's in front with 225/50 r 16's and 18's in back with 235/24 r 18's
aside from people thinking this will look bad or be dumb on a front wheel drive car is there any reasons it will not drive properly?
Re: raked look 17's in front and 18's in back
![Confused](https://acurazine.com/forums/images/smilies/confused.gif)
Originally posted by accordv6
I think it would look kinda whack on a FWD car......either get 18s or 17s....not both, it won't look right
found 235/45 r17 and 235/40r18 in bridgetone s-03 poles
what do you think will this work?
I'm beginning to doubt if this will work the konig are only +40 in the 17" and +45 in 18" I'm not sure this will work rubbing probably
working on tires alone, a 235 tire width usually is intended for an 8" or 8.5" wide rim. but let's say you get the 8s...most go with a 225 tire and a +50mm offset for the least amount of rubbing. however, you are going with 235s which means your offset should be slightly higher than 50 to compensate for the added tire width. if you really wanna do it, you will need to get nice (ie, expensive) japanese or custom made wheels...no generics!
Moderator Alumnus
I know that is usualy only found on rwd cars and like I stated before besides peoples opinions of it not being for fwd cars is there any reason I shouldn't do this i.e. allignment????
...and then there was One
Make sure both front and back have the same overall rolling diameter.
If you want to see how it would look, your local tire shop should be willing to put the wheels are your car to see if it's what you want.
so with a 40 and a 45 offset I need to stay with in the 225 with and everything should be ok????
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
Originally posted by sparky57
Not a prob if you're a big fan of understeer.
Dude, as long as both the front and rear tires are the same overall diameter, it won't be that big od deal (considering the offset is fine).
Figure that out, and you will be ok. Like, keep the stock wheels and tires on the front, and put 235/40/18's on the back. The 235/40/18's are very close to stock, so it won't be much of a difference. Now, if you want wider tires up front, just go to 225/45/17's, or 225/40/17's (a little smaller than stock, though).
Do you have any tire height calculators? There are quite a few on the web; people have posted links to them on this site.
That is really not that helpful. I have no idea what you mean by this. are you saying that if I do this I will have more understear then if I stay with the same rims all the way around???
Rear wheel drive cars tuned for performance such as the NSX or the S2000 (got one of those, too) are balanced for a more neutral handling state. They stagger the wheel and/or tire sizes as part of the chassis tuning. What works for them does not work for FWD designs.
If looks trump handling, then go for it. Otherwise, trust the chassis engineers.
rw
yeah, so long as you have the same rolling diameter and the offsets are fine, it'll be ok. You just can't rotate your tires (well, I guess you can, but that would really look funny!).
I had my s2000 wheels on my TL before, although they were the same diameter, the fronts were more narrow than the rear. It drove fine!
http://www.socal28.com
as far as how the 17 in front and 18 in back will look... that is personal opinion.... personally i dont like that look but if it make you happy do it... now for a bit of logic.... there is a major disadvantage to not going with the same size tire all the way around... now if have different sizes in the front and back you will be unable to rotate your tires when you notice uneven tire wear.... this mean you will get less life out of your tires....just my 2 cents...
don't u think it will also affect the handling and cornering abilities...that setup might be crucial for rear wheel drive cars but it could be poison to front wheel drive cars...
my 2 cents
my 2 cents
NSX & 3.2TL
If you want that "raked" look, just lower the car a little more in the front. That's why lowered cars like BMWs and MBs look so cool, and they have wheels of the same diameter both front and back.
i have comptech already and was only thinking of my 91 zr1 with the diffrent series tires front and back and was thinking it might be cool to have diffrent sizes front and back but you are all right it's not really for a tl so I'm looking for other solutions now. Might just go for a c32 and forget about acura's gremlins
Marmbo
4G TL Problems & Fixes
09-21-2015 09:39 AM
nuldabz
09-03-2015 05:49 PM
