question for H&R spring owners
looking to pick up a set of the H&Rs springs for my TL-S. i know the site and threads have said its 1.4F and 1.3R (something like that) but i'm more of a visual guy. so in finger gap measurements!(truely scientific) how much of a gap do you guys have and is the drop severe enough for you guys to get a camber kit? yes i have used the search tool but all i've been getting is that "H&R is excluded from your search" which is buggin the hell out of me. thanks for any help and/or advice
i got tein s-techs and its about the same drop. I didnt get a chamber kit, i was told if i go lower then its required. most people with coilovers get them because the drop is more then 1.5 inches....
AZ Community Team
Received 7,771 Likes
Depends on exact tire size.
With stock tires (235/45-17) my gap was 1 finger front, ~1.5 finger rear, iirc.
With 245/45-17 (about 1/8th inch taller) my gap is ~3/4 finger front, 1 finger back.
No camber kit 14k miles tires are fine. Minor wear on the inner edge, but not a big deal. Toe Alignment is checked/adjusted every other tire rotation (~9k miles).
AZ Community Team
AZ Community Team
I figure, they'll last as long as they last. When (if) they are shot, Koni's are just a phone call away.
i had H&R sports on my 08' TL Type-S on factory shocks pictured below. tire profile were 245/35R19 (front) & 275/30R19 (rear) IMO, your going to want to go lower. my best recommendation is to go with a coilover setup such as the H&R coilovers or Tein Basics/SS. trust me on this one.
Go to www.H&Rsprings.com and look at the application guide. H&R part no. 50104-88 is only listed for the TL base.
You are wrong.
SlammedOnKonis
Wrong.
You are wrong.
You are wrong.
How does that make me wrong? It's pretty much common knowledge...
"Like None Other"
^^^the drop is PERFECT to me...
i wouldn't mind a coil-over setup but at this point i don't think the 1k+ is warranted. its bout to be spring in utah and the car is going into storage mid-summer and hopefully going to end up in someplace with tropical weather all year round. like bear said before, if i want to go lower imma just get new shocks. but thanks for the input.
Will they clear Brembos?
I like the looks of the H&R Sports on DREW's car, that's about the drop I'm looking for as I have a nasty ridge to my parking lot behind my work, and the occasional dirt road here in Vermont.
I have H&R Sports on my Legacy and they're great.
Looks like the H&R Sports give a slight rake to the front of the TL-S 6MT. With an Auto TL-S, it'd sit even lower up front considering TL-S 5AT weighs about 100lbs more in front. That might be a little too aggressive of a rake but someone else can chime in.
Zonian22
11-14-2015 01:20 PM
