Is it possible to install a TPMS on a 2004 TL and have it wired to an '07-'08 gauge?
I have been looking to order a new gauge cluster and steering wheel for my 04 TL to give it more of the 07-08 look. I know that the 07-08 cluster includes a TPM on the screen. I read up on installing those clusters on the 04 and people said that the TPM screen flashes constantly unless you bypass the screen... I do like the TPMS so I was just wondering is it possible to install a TPMS on my 04 TL and how would you do it?
I'm sort of interested in this also.
After I had a Type-S gauge in my possession I've always loved the look.
The only thing that stopped me was the airbag indicator (easy fix, cover the light) and the TPMS error message (shows up on MID every time you start your car, push select to dismiss the message. kind of annoying).
I believe the member chad05TL on here did it according to this thread:
https://acurazine.com/forums/audio-b...2015-a-923542/
I feel like it would be quite tricky, as there are sensors at each wheelwell, and they are probably wired up to the ecm or something in the dash. I do like how in the TL, it shows individual tire pressures, which is a benefit of having individual sensors at each wheelwell
you might need a TPMS receiver from 07-08 TL, but the money question is where does that receiver hook up to? car PCM? if so I do not think the 04-06 tl ECU interchangeable with 07-08 (I might be wrong on this one).
no that is the sender unit, all four send to a receiver which display on the MID, FIY OEM 07-08 TMPS only $39.
maska (02-25-2018)
RxWorld
24
05-03-2016 02:42 AM
iSeeYouTwo
11-27-2015 11:43 PM
