Painting your own wheels problem
Hey, I was wondering if anyone could tell me why my wheels appear to be dusty at the end? followed every step, did a really good job sanding and prepping, no luck and this is the second time ive tried it and same result. I put 2 coats of primer, 3 of paint, 2 of clear. Primer is Krylon Rust something, and the paint is engine duplicolor black.
attached are some pictures, let me know.
Also, I dont want to hear any of this... go get them powedercoated its so much better, I KNOW.
The can held too far could also cause roughness as well. Spray can paint tends to flash very fast. You want to keep the coat wet and cover the part fast.
When its too far, the atomized paint can start to dry in the air before it hit the surface, if its a paint that flashes very fast combined with hot, dry surrounding air.
Try polishing compound too, on the cured coating.
Chessie724 (08-21-2012)
It could be either the paint itself or the clear coat. When I did my rims severea years back i dnt exactly remember if it was the paint or clear coat but once i sprayed em the wheel turned into a weird texture. i had to re-sand and change (again dnt recall if it was paint or clear coat)
Sharing info, but most titles(questions) that new members ask discussed numerous times before on this forum. Search is your friend. Hell, I searched all the time when i was newbie. I still do. Search function on AZ sucks IMO. Google is your buddy!!! Like shark said, try google search. It shows everything. If you want to search specifically for TL, just type question and type acurazine or 3g tl next to that question. It will show a lot of related threads.
nanos
11-12-2015 08:41 PM
merc009
10-03-2015 12:59 AM
detailersdomain
Wash & Wax
09-03-2015 10:56 PM
