NEX coilovers question
Hi guys. im about to pick up a set of NEX coilovers. I heard that they actually ride kinda rough and that I could change the springs to make it ride smoother??. If so, do you guys know what springs are compatable yet smooth or comforting with the NEX coilovers? TIA
Registered speed offender
i dont mean any offence,but dosent that defeat the whole purpose of spending 5-700 dollars on a kit,by going and spending more money on new springs to replace the ones that are brand new?
wouldnt it be the same price just to go with some tein basics,or maybe konis/springs even though there is no height adjustment like coilovers?
im actually gonna buy the suspension for 300 and springs go for 2-300? so it will even out to 5-600. i just want to know what springs will fit PERFECTLY onto the NEX struts
I have car ADD
honestly... dont know much about the NEX .. and ive been doing alot of research of the difference in coilovers on the market....
for $600. spring the extra $70 and get the tein basics... because the springs are paired with the right struts
or, buy koni adjustables and some comptech springs.... good combo
Originally Posted by stillhere153
or you can get koni yellow struts and put ground control coilover sleeves (which have eibach springs)
agreed.. i'd say the best set up.
if it wasn't for the EDFC, i woulda went this way also.
94 DC4 RS LSV/Turbo
edfc? are you that lazy j/k
I mean the edfc is the shiznit... I would do it also but no one has stepped up and released an edfc compatible strut bar
94 DC4 RS LSV/Turbo
Originally Posted by Wseminuk
the koni and comptech i mean
excelerate can work out a deal for you for somewhere just over $700
or you can buy the comptechs from him for $135 and get the neuspeed koni setup (super cup kit) from neuspeeds website... neuspeed.com (look for accord v6 03+ silver cup kit)
06 6spd TL BAGGED
walker all u need is the springs... just a pair for the rears. the size is 2.25" diameter i think... ill double check though. springs go for $70 each and you can choose how much lbs. for the spring rate. the fronts are fine.
ONE MORE QUESTION: Where can I get those rubber bushings that go on the bottom of the REAR system? Theres that rubber/metal bushing that goes inside of the bottome of the coilover system on the rear shocks. Any websites? oh this if for the NEX suspension. idk if they are pretty much the same size for all systems. any information will help. thanx guys
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
4drviper
09-23-2015 07:42 PM
