New Wheel/Tire specs thread with pics
#522
2011 CR-Z EX 6spd Navi
Here's some pics from when I was running 17x8 +32 Work Emotion CR Kai on my 2005 TL 6spd (clears Brembos with plenty of room to spare)
I just picked up a set of EVO IX RS 17x8 et38 wheels though for winter so I'll probably get rid of the Work wheels in Spring once it gets warmer
1.Brand of Rim : Work Emotion CR Kai (Gunmetal)
2.Rim size (diameter and width) : 17x8
3.Offset : +32
4.Brand of tire : BFGoodrich KDW
5.Tire size : 235/45-17
6.Drop Type and Amount : stock height
7.Do they rub : no rubbing
8. Transmission type : 6spd (plenty of clearance for Brembo calipers)
![Name: 1.jpg
Size: 98.4 KB](https://acurazine.com/forums/attachments/3g-tl-tires-wheels-suspension-97/53159d1501294184-new-wheel-tire-specs-thread-pics-1.jpg)
3.Offset : +32
![Name: 1.jpg
![Name: 2.jpg
Size: 106.4 KB](https://acurazine.com/forums/attachments/3g-tl-tires-wheels-suspension-97/53160d1501294184-new-wheel-tire-specs-thread-pics-2.jpg)
#523
BE by Breyton w/Michelin Pilot Sport A/S Plus
2008 Base TL
1.Brand of Rim - BE by Breyton
2.Rim size (diameter and width) - 18" x 8"
3.Offset - 45mm
4.Brand of tire - Michelin Pilot Sport A/S Plus
5.Tire size - 235/40/18
6.Drop Type and Amount - none (stock)
7.Do they rub - No rubbing
8. Transmission type (use of spacers if 6MT) - 5AT
9. Picture
![](http://img96.imageshack.us/img96/9784/newwheels1.jpg)
![](http://img25.imageshack.us/img25/984/newwheels2.jpg)
![](http://img191.imageshack.us/img191/1178/newwheels5.jpg)
3.Offset - 45mm
9. Picture
![](http://img197.imageshack.us/img197/5288/newwheels3.jpg)
#525
DER NEUE ^
![Thumbs up](https://acurazine.com/forums/images/icons/icon14.gif)
1. Brand of Rim : Original 04 A-spec package wheels by Enkei (Gunmetal/Anthracite)
2. Rim size (diameter and width) : 18x8.5
3. Offset : +45
4. Brand of tire : BFGoodrich g-Force SS A/S
5. Tire size : 245/40ZR18 93W SL
6. Drop Type and Amount : 6MT A-spec suspension (approx. 3/4" drop, 2 fingers btw fender+tire)
7. Do they rub : None
8. Transmission type : 6MT, no spacers needed to clear the front Brembo calipers
9. Picture
3. Offset : +45
9. Picture
![](http://img56.imageshack.us/img56/7247/img5528bw4.jpg)
#527
FL 04 dgp TL
1. Brand of Rim : Privat Rennstadt
3. Offset : ?
4. Brand of tire : funny tires
5. Tire size : 235/40 ZR18
6. Drop Type and Amount : hr sprngs with koni sp3 shocks. middle perch on front lowest perch on rear
8. Transmission type : 5AT
![](https://acurazine.com/forums/picture.php?albumid=1975&pictureid=39226)
![](https://acurazine.com/forums/picture.php?albumid=1975&pictureid=39227)
3. Offset : ?
#532
MechEng
1.Brand of Rim - Algernon Intelesse
2.Rim size (diameter and width) - 19*8 19*9
3.Offset - 38mm
4.Brand of tire - Falken 452
5.Tire size - 225/35 235/35
6.Drop Type and Amount - Eibach Race(TSX)
7.Do they rub - Rear because of spacers, needs roll
8. Transmission type (use of spacers if 6MT) - 6MT 15mm 20mm
9. Picture
![](http://i4.photobucket.com/albums/y128/luder917/Acura%20TL%20with%20Algernon%20Intelesse/TLrims-1.jpg)
3.Offset - 38mm
9. Picture
#536
1.Brand/Model of Rim - XXR/502 (Chromium Black color)
2.Rim size (diameter and width) - 18x8.5 front, 18x9.5 rear
3.Offset - 35mm
4.Brand of tire - Continental ExtremeContact DWS
5.Tire size - 245/40-18 front, 255/40-18 rear
6.Drop Type and Amount - No drop
7.Do they rub - Rears rub slightly, where factory roll ends, when
trunk is loaded.
8. Transmission type (use of spacers if 6MT) - Auto
9. Picture: Here is the picture link below:
http://s175.photobucket.com/albums/w.../Red%20Rocket/
3.Offset - 35mm
trunk is loaded.
#538
3. Offset : +45
9. Picture
3. Offset : +45
9. Picture
#539
WiCk3D >TL TyPe-S< iN
#540
1. Brand of Rim : XXR 962
2. Rim size (diameter and width) : 18/8.5 F<> <>18/9.5 R
3. Offset : UNKNOW ??
4. Brand of tire : UNKNOW ??
5. Tire size : 235/35-40/18 F<> <> 245/35-40/18 R
6. Drop Type and Amount : TEIN BASIC
7. Do they rub : UNKNOW ??
PIC SOON TO COME >>>>
http://www.xxrwheels.com/sportmax_962.shtml#
#541
1.Brand of Rim - Concept One Rs8
2.Rim size (diameter and width) - 19x9.5
3.Offset - +42(F) , +42 (R)
4.Brand of tire - Pirelli P zero Rosso
5.Tire size - 255 35 19
6.Drop Type and Amount - FnF Type 1/HTspec type 1.... Low...LOL
7.Do they rub - No rubbing/ rear fenders rolled
8. Transmission type Auto
![Name: 190827_1970927073141_1241919931_2427649_8060304_o.jpg
Size: 71.6 KB](https://acurazine.com/forums/attachments/3g-tl-tires-wheels-suspension-97/52651d1501293050-new-wheel-tire-specs-thread-pics-190827_1970927073141_1241919931_2427649_8060304_o.jpg)
![](http://i23.photobucket.com/albums/b391/SteelEG/209996_1970927793159_1241919931_2427650_8133257_o.jpg)
![Name: 191254_1970928953188_1241919931_2427656_1044577_o-1.jpg
Size: 72.0 KB](https://acurazine.com/forums/attachments/3g-tl-tires-wheels-suspension-97/52652d1501293050-new-wheel-tire-specs-thread-pics-191254_1970928953188_1241919931_2427656_1044577_o-1.jpg)
JD TL-S (11-30-2011)
#544
![](http://i23.photobucket.com/albums/b391/SteelEG/190827_1970927073141_1241919931_2427649_8060304_o.jpg)
![](http://i23.photobucket.com/albums/b391/SteelEG/191254_1970928953188_1241919931_2427656_1044577_o-1.jpg)
#545
1.Brand of Rim - Work VS-XX
2.Rim size (diameter and width) - 19" x 8.5" Front 19" x 10" Rear
3.Offset - 33mm with 15mm spacer Front (18mm), 33mm Rear
4.Brand of tire - Toyo Proxes T1S
5.Tire size - 225/35/19 Front, 255/30/19 Rear
6.Drop Type and Amount - BC Racing Coilovers, 1 finger at 45 degree angle fender gap drop
7.Do they rub - All fenders rolled, but still YES! (only rear)
8. Transmission type (use of spacers if 6MT) - TLS 5AT
9. Picture
![Name: 5610281889_bab5e47119_b.jpg
Size: 128.2 KB](https://acurazine.com/forums/attachments/3g-tl-tires-wheels-suspension-97/52603d1501292954-new-wheel-tire-specs-thread-pics-5610281889_bab5e47119_b.jpg)
![Name: 5610853210_2a1bb66512_b.jpg
Size: 142.5 KB](https://acurazine.com/forums/attachments/3g-tl-tires-wheels-suspension-97/52604d1501292954-new-wheel-tire-specs-thread-pics-5610853210_2a1bb66512_b.jpg)
9. Picture
![Name: 5610266551_f081005931_b.jpg
Size: 216.2 KB](https://acurazine.com/forums/attachments/3g-tl-tires-wheels-suspension-97/52605d1501292954-new-wheel-tire-specs-thread-pics-5610266551_f081005931_b.jpg)
The following 2 users liked this post by Ch33sE1:
JD TL-S (11-30-2011),
obsolete83 (09-06-2014)
#546
1.brand of rim - work vs-xx
2.rim size (diameter and width) - 19" x 8.5" front 19" x 10" rear
3.offset - 33mm with 15mm spacer front (18mm), 33mm rear
4.brand of tire - toyo proxes t1s
5.tire size - 225/35/19 front, 255/30/19 rear
6.drop type and amount - bc racing coilovers, 1 finger at 45 degree angle fender gap drop
7.do they rub - all fenders rolled, but still yes! (only rear)
8. Transmission type (use of spacers if 6mt) - tls 5at
9. Picture
![](https://i206.photobucket.com/albums/bb255/ch33se1/tl%20type%20s/5610281889_bab5e47119_b.jpg)
![](https://i206.photobucket.com/albums/bb255/ch33se1/tl%20type%20s/5610853210_2a1bb66512_b.jpg)
![](https://i206.photobucket.com/albums/bb255/ch33se1/tl%20type%20s/5610266551_f081005931_b.jpg)
9. Picture
dame so fucking sexy...i am really feeling the blue tl-s and the work vs-xx....mad sexy....big up ...
#548
1.Brand of Rim - Enkei Falcon in hyper silver
2.Rim size (diameter and width) - 17" x 8"
3.Offset - 45mm
4.Brand of tire - Continental Extreme Contact DW
5.Tire size - 235/45/17
6.Drop Type and Amount - 0 drop
8. Transmission type (use of spacers if 6MT) - Auto, 5mm spacer
![Name: SAM_0509.jpg
Size: 173.8 KB](https://acurazine.com/forums/attachments/3g-tl-tires-wheels-suspension-97/52533d1501292836-new-wheel-tire-specs-thread-pics-sam_0509.jpg)
3.Offset - 45mm
![Name: SAM_0510.jpg
Size: 122.6 KB](https://acurazine.com/forums/attachments/3g-tl-tires-wheels-suspension-97/52534d1501292836-new-wheel-tire-specs-thread-pics-sam_0510.jpg)
#549
FL 04 dgp TL
1.Brand of Rim - Rota G Force gunmetal
2.Rim size (diameter and width) - 18" x 9"
3.Offset - 30mm
4.Brand of tire - NEXEN
6.Drop Type and Amount - 2 inches at least with Koni SP3
![](https://acurazine.com/forums/picture.php?albumid=1975&pictureid=42552)
![](https://acurazine.com/forums/members/tbdefense20-235223-albums-04-acura-tl-deep-green-pearl-1975-picture-img-0345-39472.jpg)
3.Offset - 30mm
#550
1.Brand of Rim : RonJon Legends (liquid graphite)
2.Rim size (diameter and width) : 19X8.5
3.Offset : Dont remember...?
4.Brand of tire : General Exclaim UHP
5.Tire size : 245/35-R19
6.Drop Type and Amount : Neuspeed Supercup Kit (approx. 1.25 inch drop)
7.Do they rub : In front, yes, if i turn too sharply..
![Name: 08TLType-S-3.jpg
Size: 98.5 KB](https://acurazine.com/forums/attachments/3g-tl-tires-wheels-suspension-97/52484d1501292561-new-wheel-tire-specs-thread-pics-08tltype-s-3.jpg)
![Name: 08TLType-S.jpg
Size: 114.1 KB](https://acurazine.com/forums/attachments/3g-tl-tires-wheels-suspension-97/52485d1501292561-new-wheel-tire-specs-thread-pics-08tltype-s.jpg)
![Name: 08TLType-S-2.jpg
Size: 102.1 KB](https://acurazine.com/forums/attachments/3g-tl-tires-wheels-suspension-97/52486d1501292561-new-wheel-tire-specs-thread-pics-08tltype-s-2.jpg)
#555
those wheels are just sick...
#556
FL 04 dgp TL
3.Offset - 30mm
![](https://acurazine.com/forums/members/tbdefense20-235223-albums-04-acura-tl-deep-green-pearl-1975-picture-img-0709-44035.jpg)
![](https://acurazine.com/forums/members/tbdefense20-235223-albums-04-acura-tl-deep-green-pearl-1975-picture-custom-tailights-acktl05-43514.jpg)
didnt like the gunmetal so i painted my rims glossy black
The following 2 users liked this post by tbdefense20:
Emersont503 (02-23-2012),
LeMix (03-05-2013)
#557
Q('.')=O
9. Picture
![](http://i206.photobucket.com/albums/bb255/Ch33sE1/TL%20Type%20S/5610281889_bab5e47119_b.jpg)
![](http://i206.photobucket.com/albums/bb255/Ch33sE1/TL%20Type%20S/5610853210_2a1bb66512_b.jpg)
![](http://i206.photobucket.com/albums/bb255/Ch33sE1/TL%20Type%20S/5610266551_f081005931_b.jpg)
9. Picture
![Pimp](https://acurazine.com/forums/images/smilies/pimp.gif)
#558
What Helo's are these, couldn't find them in 20's, they look good.
#559
#560
1.Brand of Rim - VIP Status
2.Rim size (diameter and width) - 18'' x 8''
3.Offset - 40
4.Brand of tire - Michelin Pilot Sport 2 A/S
6.Drop Type and Amount - no drop (thats next)
8. Transmission type (use of spacers if 6MT) - 6MT, no spacers
9. Picture
![Name: IMG_0892.jpg
Size: 60.8 KB](https://acurazine.com/forums/attachments/3g-tl-tires-wheels-suspension-97/52354d1501291872-new-wheel-tire-specs-thread-pics-img_0892.jpg)
![Name: IMG_0890.jpg
Size: 54.6 KB](https://acurazine.com/forums/attachments/3g-tl-tires-wheels-suspension-97/52355d1501291872-new-wheel-tire-specs-thread-pics-img_0890.jpg)
3.Offset - 40
9. Picture
![Name: IMG_0882.jpg
Size: 64.7 KB](https://acurazine.com/forums/attachments/3g-tl-tires-wheels-suspension-97/52356d1501291872-new-wheel-tire-specs-thread-pics-img_0882.jpg)
