Need measurement
Old 03-16-2017, 09:00 AM
sockr1's Avatar
Received 1,158 Likes on 909 Posts
Need measurement
Can someone provide the following measurement that has a stock suspension? It's just the length from the center of the wheel vertically up until the apex of the fender. I never took this measurement before I lowered my car so I don't technically know how low I am (I'm not that low). Again this must be from a stock suspension and ideally measured on each of the four wheels
thanks in advance!
Old 03-16-2017, 10:01 AM
Received 16,260 Likes on 11,971 Posts
when i raised my car last month, i tried to search a little. i've found the aspec had a measurement from the ground to the apex of 26 inches for the rear. and what I raised my car too
for the front, I eyeballed and settled with a tight two finger gap. the rear is a tight 3 finger gap...but we all have different sized fingers...lol
Old 03-16-2017, 10:05 AM
sockr1's Avatar
^ yea I'm looking for the hub center to fender measurement because that is more accurate than ground to fender. Ground to fender changes based on wheel size and tire size whereas hub to fender is a direct correlation to ride height without an influence from the tires or wheels (just suspension)
plus what if i have small fingers lol it would make me seem more lowered than I am!! Lol
justnspace (03-16-2017)
Old 03-16-2017, 10:19 AM
i know, i just like inputting my opinion.
sockr1 (03-16-2017)
Old 03-16-2017, 10:55 AM
BROlando's Avatar
Received 1,169 Likes on 879 Posts
I meant to measure the last one I lowered. But I was eating a sandwich at the time...so I forgot.
My fingers are like that of a lady.
Is any of this helpful AF?
LMK.
Old 03-16-2017, 11:05 AM
BROlando's Avatar
^Sorry, NVM those pics. The rear had a box of coilovers in it.
How accurate are you looking to get this info? If its really just for reference to see how much you lowered it, a typical measurement may work.
I would assume accuracy of (+/-) 1", though. Hub to arch is difficult because centre points are hard to see...and depending on fuel level and junk in the trunk...it will vary.
17 gallons of gas weighs ~104LB.
And you'd want to do this on a level surface.
An empty car with a full tank on an alignment rack would be a good "standard" to use, if someone can swing that.
Sorry if I'm being too ANALytical.
sockr1 (03-16-2017)
Old 03-16-2017, 12:40 PM
sockr1's Avatar
yea just trying to get a ballpark. i just measured mine and i'm about 12.5" for that measurement (give or take .5" or so). just looking for a generic baseline so i'm not lying when i say i'm x.x lowered haha.
and a somewhat related note, i'm going to send you a PM, i want to pick your brain on some tein flex measurements
Old 03-16-2017, 12:45 PM
btw, off topic....
I lost one exhaust garnish....
shit flew off somewhere
I knew I should have secured it. that was my bad
Old 03-16-2017, 01:07 PM
sockr1's Avatar
btw, off topic....
damn it lol!! did you use the clips?
Old 03-16-2017, 07:48 PM
-------Tim-------
Slpr04UA6's Avatar
btw, off topic....
Was this after the curb?
Old Joke, but couldn't resist!
j/k
Old 03-16-2017, 08:01 PM
Turbonut's Avatar
'04 Stock:
Front 14.75"
Rear 14.50"
sockr1 (03-16-2017)
Old 03-16-2017, 09:33 PM
sockr1's Avatar
Originally Posted by Turbonut
'04 Stock:
Front 14.75"
Rear 14.50"
thank you!! Looks like I'm 2" lowered.
Old 03-16-2017, 11:47 PM
truonghthe's Avatar
Received 1,687 Likes on 1,303 Posts
I will measure my Type S this weekend and will post the result. My shit guarantee to be 150% stock.
sockr1 (03-17-2017)
Old 03-17-2017, 09:24 PM
Le7316's Avatar
I am 100% Stock too lol
Old 03-17-2017, 11:55 PM
Received 8,603 Likes on 6,645 Posts
14.75" all around
08 Type S
Near empty gas tank
sockr1 (03-17-2017)
