Need help/ desperate!
alright guys, sorry if there will be spelling errors I'm doing this off my iPhone, I can't take the 17mm bolt that connects the coil holder to the lower control arm. I have soaked it for 3 days with PB blaster. Took a torch to it. Took a impact wrench to it, it won't bugde. I took the bolt off facing towards the rear easily. But I can't get the actual bolt to come out, can you guys help? Any suggestions?
the bolt you're referring to has a tendency to become seized/frozen in place.
what I had to do with mine was cut the bolt in half with a saw-zall and metal cutting blade. you're going to have to cut it between the control arm itself and the area on the other side of the 17mm head. <-hope that makes sense.
I was able to cut my bolt in half within 5 mins that way (after hours of other methods)
you can get a replacement bolt from Honda for like $5
