Need help
Old Jul 30, 2018 | 09:33 PM
Rnoonan23's Avatar
7th Gear
Need help
ok so let me start by saying wat I did so far I did bc all around and front upper control arm skunk2 and did the stabilizer links and did rear spc adjustable link top one that it I have my bc set up at mid 6 it was on hard and move it down to 6 so far rear really good but the front end feel like crap can anyone one guild me it’s jumps more then it used to I’m thinking if I have to replay more front end parts??
Old Jul 31, 2018 | 11:01 AM
Jackass's Avatar
I can't even read this due to the lack of punctuation.
Old Jul 31, 2018 | 01:52 PM
BreezyTL's Avatar
if i were you i would try to set the damper settings back to the recommended levels then i would ride around and try adjusting them to your personal preference then i would learn how to use punctuation so we can figure out what you are actually try to explain after all that nonsense i dont know where to go from there as i am lost in my own train of thought since i didnt use any punctuation myself
:fml:
Old Jul 31, 2018 | 02:27 PM
Rnoonan23's Avatar
7th Gear
dam like that wow I can read it just fine must be u guys but anyway like I said the ride is perfect but I just feel like the shock Jump to much I’m not suppose to here anything but the road I turn them to five which is good but I feel like I have to replace something els maybe lower ball joint or lower arm something not right brand new tires brand new upper skunk2 new stabilizer link
Old Jul 31, 2018 | 02:39 PM
Jackass's Avatar
shocks don't jump they dampen so maybe check the condition of all of your components like shocks springs bushings once that is confirmed to be ok start looking at other items like tires and such what exactly feels like crap is it the harshness of bumps is it the impact of bumps does it bob up and down a bunch is it noisy do you feel it hitting the bump stops does it track straight down the road has it been aligned recently
Old Jul 31, 2018 | 05:25 PM
BROlando's Avatar
this isn't grammarzine...so it doesn't have to be perfect....and English may not be your first language....
But I can't understand a COT dang thing you're trying to say in your first post either. You can probably read it fine because you're the one who wrote it.
Why not just make it easy for people to help you if you need help?
Old Jul 31, 2018 | 09:45 PM
Rnoonan23's Avatar
7th Gear
I set them back to hard and went back 3 clicks on all of them I have no problem in the real only the front it feels like shocks are going but they are brand new bc out the box maybe lower arm meanwhile I never replace nothing in the front end I had this car 3 yrs now so far so good just trying to do few mods here and there I feel like replacing all front end parts any idea on good brands or adjustable ones??
QUOTE=Jackass;16273208]shocks don't jump they dampen so maybe check the condition of all of your components like shocks springs bushings once that is confirmed to be ok start looking at other items like tires and such what exactly feels like crap is it the harshness of bumps is it the impact of bumps does it bob up and down a bunch is it noisy do you feel it hitting the bump stops does it track straight down the road has it been aligned recently[/QUOTE]
Old Aug 1, 2018 | 04:30 AM
Joecop67's Avatar
Still no punctuation. Lol.
Old Aug 1, 2018 | 12:12 PM
90foxnotch's Avatar
Go to a shop for an alignment and maybe they can help with your other issues.
Old Aug 4, 2018 | 10:46 PM
csmeance's Avatar
set your preload properly first on the front setup
Nautsiju
Mar 7, 2008 07:32 PM
bigboyx66
Apr 21, 2004 01:52 AM
CBS
Mar 6, 2003 08:30 AM
2K1NighthawkTL
Aug 9, 2001 10:55 AM
