Help...help...i need help....
Old Mar 5, 2003 | 08:19 PM
CBS
Hey guys,
I was in the process of taking out my tails(on my TL) and 2 out of the 6 nuts got stripped!!! How can i get them out? I tried wd-40 and all of that and no luck. Do i get some kind of professional tool to get the nuts off or can i get a acura technician to get them off? Help cause i have one tail on and other oem one on. It looks phucked up!
Old Mar 5, 2003 | 10:15 PM
pianoman41's Avatar
If the nut is still on the threaded shaft and you stripped the corners trying to get them off, try a pair of needlenose vice grips. Now if they're stripped because they are cross-threaded on the shaft, that could be tougher.
Old Mar 5, 2003 | 10:36 PM
TLlikeWHOA's Avatar
take needle nose plyers...and pull like ur life depends on it =)
been there done that...lol
when your hands start to hurt, then u kno its getting looser..lol good luck bro
Old Mar 6, 2003 | 07:13 AM
You could break out the Dremel and cut it off.
Old Mar 6, 2003 | 08:30 AM
SlyTLS's Avatar
Bada Bing
You can also take a socket and hammer it on over the lugs then use a sturdy rachet to take them off...I know that most tire places follow this method except rather than a rachet they use their impact guns making it much easier.
This is also how to remove a wheel lock in case you don't have a key (makes you feel safe with those wheel locks don't it. )
meowCat
Jul 2, 2014 04:04 AM
honda_motor_co_4life
14
Apr 4, 2007 03:17 PM
osyrhiz
1G CL Problems & Fixes
Mar 13, 2007 01:15 PM
