My TPMS reading
Tri State ViP Crew
My TPMS reading
Im not sure if im the only one wondering but should all four tires read the same tire pressure or does it depend on driving conditions? Because I notice at times the fronts read differently from the rears. below is what mines was showing a few days ago. Should I add air to the two rear tires?
First look at your inflation specs.... the front and rear tires are not supposed to be the same pressure, and on top of that the pressures will vary with heat and load on the tires. I also don't expect the TPMS to be dead on accurate.
The TL is heavier in the front (due to front wheel drive). Higher pressure in the front tires will maintain the same area of tire contact with the road. The recommended pressures should be on the driver's door jamb. I believe mine are 35 front, 32 rear (varies with tire make/model).
The numbers will rise with temperature (while driving) so the pressure should be adjusted when cool. Universal gas law in effect there.
I've noticed my TPMS to be pretty darned accurate with my hand-held pressure gauge.
Registered but harmless
Received 1,102 Likes
Check 1) your driver's door plate/sticker, and 2) last page of your owner's manual for recommended pressures. However, some people adjust their pressure a little higher for firmer ride/better handling/better mileage (I use 36/33 generally on my 5A; just keep cold pressure below 40 psi to keep car from feeling twitchy at higher speeds).
For your peace of mind you should get yourself a good tire pressure gauge (I got a nice digital one). Go out to your car one morning when your car has been sitting all night (tire need to be cold). Locate your tire pressure sticker on your driver side door jam, and check all your tire pressures and adjust them. Don't do this after driving the car as your tire will heat up, and the pressure in the tires will increase. Tire pressures need to be checked and adjusted cold. If you don't have a air compressor at home you should invest in one of those 12v (cig lighter) compressors. You can get something good for less than $50. Then you can also keep it in your trunk, you never know when you'll need it.
Originally Posted by scadagawd
How do you change the TPMS reading from Kpa to PSI. I have the canadian model TL. Thanks.
that's interesting. When I first drove the car off the lot, it read PSI, but after I hit the Default settings reset button for the keyless memory option, I noticed it reverted back to kpa?
mjfpjf
TPMS Setpoint?
My tire pressure warning came on this afternoon when I started up the car. Checked the tires visually and they looked ok but I've learned not to trust that. Didn't have a pressure gage (do now) and didn't know that I could read the pressures (found out a bit later) When learned how to read them, I had 28 in one front tire, 29 in the other, and 30 in both rears. After I put a bit of air in them, I had 32 all the way around and the warning cleared. My question: what is the TPMS Setpoint? My owner's manual doesn't say. Thanks in advance.
Martin Farber
Martin Farber
Always check the tires when they are cold; the tire pressure will be lower as the weather gets colder too.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
