Lowering questions
Lowering questions
Alright so i plan on lowering my car on coilovers this spring. I know people are gonna say search but I am a complete noob at suspension and cant understand half the things people say when they talk about suspension. So here are the questions
1. Whats the difference between the tein SS and the tein advance coilovers?
2. When i lowered my G on springs it only needed a rear camber kit, how would the TL go?
3. When I lower my car how do I know what kind of alignment is needed? Or will the alignment shop know what to do?
Thanks!
Thanks!
2. May need front camber too. Depends how low you go. The rear will definetly go out of camber spec first.
3. The shop will know what you need and should try to get Toe close to zero on all 4 corners, caster in spec for the front (no rear caster, iirc) and there is nothing they can do with camber - we have no stock camber adjustment at all.
As far as I can gather I'm pretty typical for the amoun of drop I have. I'm at ~1.3 inches and the front Toe, Caster and Camber are OK. The Camber is bit off the target, but in spec. On the rear, Toe is OK, 1 side camber is in spec, but barely. The other side Camber is out of spec, but just barely.
If I lowered the car further, the camber would get progressively farther out of spec. Or, if I have a load in the trunk, it will pull the camber more out spec.
Tein coilovers are performance oriented, which means they are made to last very long and to give you a harsh ride.
For a performance perspective, you cannot go too low with coilovers. That gives your shorter suspension traveling distance and big droops, which means your car will corner terribly.
If you just want to slam your car, get a set of lowering springs.
There are different types of coilovers that can accomodate for the shorter travel.... Do some homework...
If you DO want to "slam" your car, you NEED coilovers, only way you will be able to lower it properly.
Yes, I do run coilovers Tein SS with EDFC to help with the "harsh" ride. Me personally am on 20's with 30 series tires at the lowest possible level on Tein coilovers.
To answer your three questions
similar answers like bearcat:
1. IDK
2. You will need rear camber kit. The front truly, just needs to have correct toe. But if you are anal, then they do have front camber kits ( I have not run them).
3. Anytime you play with suspension you WILL need an alignment. They will be unable to correct camber without camber kits, but can adjust toe....
question 1:https://acurazine.com/forums/3g-tl-tires-wheels-suspension-97/new-2012-tein-street-advance-coilovers-ss-successor-843546/
question 2:https://acurazine.com/forums/3g-tl-tires-wheels-suspension-97/do-i-need-camber-kit-606757/
question 3: yes the alignment tech would know what to do unless you request negative cambers.
hope this helps.
Thanks for info. The tein should be good since im not planning to go That low. One of the main reasons im getting coils is so that i can raise the car back in winter. I also noticed fuloni mentined he got edfc to help with harsh ride. What are they exacltly and what do they do?
you don't need an EDFC. all it is is a module that allows you to control how soft or hard you want the coilvers set to (how soft or stiff your ride will be). you can mount it in your car and press a button and it'll change it for you. but once you find your comfort level, you really won't mess with the settings at all. it's a luxury item that almost nobody has. is it cool? yeah, it's cool...but for $350-$400 you don't need it.
most coilovers have adjustable damper so you can set the comfort level to whatever you want. the adjustment knob is located on top of the coilvers, and is accessible easily.
I know that the front damper adjustment knobs are easy to adjust, but I thought I read that you have to take out the backseats to adjust the rears?
^yes, you do have to take out the backseats to get to the knobs...but if you take out your backseat just one time and get it down to a science, you can remove the whole thing in less than 5 mins. it's only 5 bolts total.
my point was, when i installed my coilovers, i left the back seats out and drove around, constantly changing the adjustments until i landed on a setting that i liked. i haven't touched the knobs since.
I lowered my 06 TL with Tein SS coilovers about 1.7 inches front and rear, I didnt need any camber kits. Tein SS coilovers have a range of aprox -0.9" to -2.5" lower. They recommend lowering the car -1.7 inches. Thats what I did and loved it. Plenty low, and with a 24mm Progress RSB and Summer 245/35/19" Yoko S-Drive tires, it handled AWESOME !!!!!!!!!!!!!!!
i got a set of tein advance myself..i was leaning towards tein ss or bc racing. what really sold me is this :
"it will provide the same drop ranges per application while still providing a 200% increase in dampening force feedback (softer settings feel softer, stiffer settings feel stiffer) The Tein rep also mentioned something about a certain part no longer being welded on anymore and that the threads are now zt coated (at least I think that's what he called it) which is to keep the threads from getting rusted and it keeps debris out and stuff"
basically its a much better version of the ss, its cheaper and if you decide to get EDFC it is compatible as well. i think i got a good deal for $860 shipped to my door step.
the only downside like i said before is it doesn't go lower than bc/megan/htspec and it doesn't come with top hats. i only have 33*** on my tls so i think I'm good with the top hats. good luck man and "SEARCH" my friend!
its really up to you if u have about 150-200 extra to spend on top hats. none of the twin products come with top hats (basis,advance,ss) on my opinion its a much better upgraded version of the ss with a lower price!!!
After looking around the advance look like they are good deal, and like you said even better than the ss. Im just always scared of the too good to be true scenario.
me too man. i just got it today and will install this weekend so who knows if i like it or not. However tein has always been a decent brand of coil overs so i know I'm safe there lets just see how it performs.
DiamondJoeQuimby
09-10-2015 11:40 AM
