Looking for wheel info
Hi all. I'm kind of new here. I just ordered my TL-S and would like to change the wheels. I think I figured out all the offset and size issues. I have noticed that some wheel sites offer multiple bolt patterns. What does the TL-S use for a bolt pattern - how many lugs and the spacing?
Thanks for the help.
What wheels are you deciding between?
The TL is 5X114. Offset needs to be +45 or greater. The stock wheels on the TLS are 17X6.5", with a +50 (I think) offset. The wider the wheel, the higher the offset you need. Any lower than +45 and you may have a lil' rubbin'.
Good luck. Check out the wheels section on this site, or www.autocarparts.com
Welcome to the forum...the AT Italia is the nicest wheel of those IMO and is high quality...I'd go with 18" or 19" x 7.5" if they have like a +48 or higher offset...I have 18" x 7.5" with a +45 offset and I had to do some minor trimming to avoid rubbing...BTW the stock offset of our wheels is +55, you want to get as close to that as possible to avoid rubbing issues.
wheel info
Thanks for the info and opinions, though I am still not sure what the offset really is. In other posts I have seen it stated that the offset was 48. Here I am seeing 50 and 55. So which is it?
asahrts
09-04-2015 05:55 PM
Mugen TSX
Eastern Canada
09-01-2015 11:11 PM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
