List of Lightweight/Performance Wheels THAT CLEAR BREMBO CALIPERS
#81
Wondering what fitment to get for these two 5 spoke wheels will these clear the brembo??
FIVE:AD Wheels FIVE: AD R5:F Gunmetal Wheels - FIVE:AD Wheels Wheels on sale, cheap rims, cheap wheels from FIVE:AD Wheels at discount prices
varrstoen mk1 series wheels
I don't know and trying to understand about the wheel game. Thanks guys
#82
Need your help fellas. I'm in the market for 18" Volk TE37 SL and need help with brembo clearance for the TL-S along with tires.
Here it is:
18x9 +45 - from research these should clear without a problem but may not be as concave
My questions are:
Cheers!
Here it is:
My questions are:
- Will 18x9.5 +40, +35, or +22 offsets clear? Correct me if I'm wrong: the lower the offset the deeper the concavity for these wheels.
- Will 18x9.5 poke? And will a 245 tire with a max stretch of 9.5" fit without requiring fender rolling?
Cheers!
#83
Here it is:
My questions are:
Cheers!
Here it is:
My questions are:
Cheers!
your 18x9 +45 will most likely NOT clear brembos...EDIT: I think accuratein ran 18x9.5 +43 but i don't know if he had spacers or not
+22 will generally clear, the others depends on the wheel design
9.5 will poke if the offset is a lower number than 40 (point of reference...mine is flush and i have 18x9 +32)
9.5 and a 245 will need rolled fenders at a minimum (maybe also a camber kit for more camber or pulled fenders) if you're dropped
picking the right wheel to have the right fitment and stance takes lots of research...it took me a few months to figure out my current set and my last set of wheels
#84
^^^Damn just when I start thinking I'm beginning to understand offsets.
So a lower + offset has a higher chance of clearing than higher + offset? I would have thought the opposite.
Seems I have to go back to the drawing board. My rear alignment is out of wack and one tire starting to show cords through the rubber.
#86
So for TL-S with brembos, the Volk TE37 SL in 18x9.5 with decent concavity is only attainable with the currently available +22 offset. I'm still looking into the +35 offset but from initial pics it appears more on the flat side.
Members who have ran similar specs are correct in that it will cause poke. Depending on lowering amount and tires, it will likely require fender work in the front and rear with aggressive tire stretch. Going with a staggered setup will allow for concavity in rear.
Trying to talk myself into 19" TE37 ultras in matte blue...
#87
Attempting to revive the original spirit of the thread because I found it personally very useful and also have something to contribute now. Thanks OP for starting this, (IMHO) it remains relevant!
+1 for making it a sticky.
Tried to clean up the formatting and fix the broken links as best as I could.
Acura A-spec wheels 18x8” +45 (~30lbs)
Acura A-spec wheels 18x8.5” +45
Acura TL Type-S honeycomb/waffle wheels 17x8” +45 (~22lbs)
Advan RS 18x9” +22 (18lbs) (Picture)
Advanti Racing Deriva 18x9.5" +22 (~22lbs)
BBS Evo X MR OEM wheels 18x8.5" +38 (~18.5lb) (Pic1)(Pic2)
Enkei Kojin 17x9" +45 (~20lbs)
Enkei NT03 18x9.5” +22
Enkei NT03 18x7.5" +37 (~20lbs)
Enkei RPF-01 17x8” +35 (picture)
Enkei RPF-01 17x8.5” +40 (16.0lbs) (link)
Enkei RPF-01 17x9” +22 (16.75lbs) (picture 1 2)
Enkei RPF-01 17x9.5” +18
Enkei PF01 18x8.5” +35 (18.6 lbs)
Forgestar F14 18x9” +29 (22lbs) (picture)
Forgestar F14 19x8.5” +35
Forgestar F14 19x9” +25 (picture)
Forgestar F14 18x8.5” +33 (19lbs 15.5 oz)
Forgestar F14 18x8.5” +26 (20 lbs 1oz)
MSR Series 045 18x8” +35 (21.9 lbs)
Prodrive GC-05F Monoblock 18x9.5” +22 (18lbs)
Racing Hart CP-035 17x8” +38 (will fit with 10mm spacers) (13.9 lbs)
Rays Engineering A34 19x8.5” +35 (19lbs).
Rays Engineering 57F 18x8.5" +45 (~17lbs)
SSR Type F 19x8.5” +42 (19.7 lb)
Volk CE28 18x8.5” +40
Volk TE37SL 18x9.5” +22 (18lbs)
Volk TE37/LE37T 19x9.5” +35
Volk TE37 19x8” +43
Volk RE30 18x9.5” +35
Weds Sport SA-70 17x9” +35 (picture)
Work VS-XX 19x9.5” +28 (picture)
Lightweight but no offsets so not sure which offset works
5Zigen Beckets FN-01R 17x8” (14.70lb)
Buddy Club P1 Racing QF 17x8” (13.60lb)
Motegi Racing Trak Lite 2 17x8” (14.60lb)
Motegi Racing Trak Lite 17x8” (15.00lb)
Racing Sparco LE 17x8” (14.60lb)
SSR Type-C (called Competitions in the US) 17x8” (14.30lb)
SSR Type-C (called Competitions in the US) 17x8.5” (15.00lb)
Wed's TC-005 17x8” (14.90lb)
Wed's TC-105N 17x8” (14.90lb)
Unverified suggestions that may work (wheels designed for BBKs)
Enkei GTC-01 18x8" +45 (20.6lb)
Enkei OEM Nissan 350Z Track V.1 F 18x8" +30 (18.2lb) / R 18x8.5" +33 (18.6lb)
Tirerack.com search, specific to Type S
Rules and Legend:
If you are unsure of the weight of the wheel, please highlight the weight in Red font and hopefully someone on here who knows the actual weight will come and correct it.
Wheels that do not clear the Brembos will be highlighted in Purple font. This information will be useful to perspective buyers so that they know what size they can not fit.
Also, lets keep this list in alphabetical order in the case that this list becomes rather large. It will make the information on here a heck-of-a-lot easier to find.
HYPERLINK pictures, don't post photos on the list.
Volk TE37 19x8” +43
Rules and Legend:
#88
ReDevil
Volk TE37 19x8” +43
Rules and Legend:
Volk TE37 19x8” +43
Rules and Legend:
#90
Cosmis Racing / MRII / 18x8.5 / +22 / 22lbs / Brembo Clearance Story by GOOSEej | Photobucket
I will upload pictures of wheel and the caliper to the album.. This was just a acquaintance car
#93
RPF1+RS3 FTW
Cosmis Racing / MRII / 18x8.5 / +22 / 22lbs / Brembo Clearance Story by GOOSEej Photobucket
#94
Volk TE37 19x8” +43
F1R FF2718855120114335731GM 18x8.5 +35 ( weight unsure) 5x114.3 & 5x120
Rules and Legend:
Volk TE37 19x8” +43
Rules and Legend:
#95
I just purchased a 2008 TL Type S with aftermarket rims already installed. From the pics, they appear to be Drag DR31 ( http://www.dragwheels.com/product.php?id=166 ). The previous owner installed factory size tires, but unfortunately I don't know the specs of the wheels (I assume 17x8, and probably +47, since it's closer to the OEM than the +35 option, but can't say for sure). I can measure them and update once I take them off. Added to the "no offsets" list below, pics here: Imgur: The most awesome images on the Internet .
Volk TE37 19x8” +43
Drag DR31 17" (unsure of width and offset) (21lb for 17x8) (Pictures)
Rules and Legend:
Volk TE37 19x8” +43
Rules and Legend:
#98
Ugh, I'm starting to hate these Brembos!!!
(can't find wheels I want that fit)
Edit: Anyone know if Enkei RPF1 in 18x9 +35 clear?
#101
Volk TE37 19x8” +43
Konig Milligram 18x8.5 +35 18.5lbs
Volk TE37 19x8” +43
#102
Does anyone know if the Enkei RS05RR wheel 18x10 wheels fit over the Brembo's? Specifically the 22mm offset.
#104
These Enkei wheels easily clear the Brembo calipers:
Enkei TX5 17x9” +45 (20 lbs) (TX5 | Enkei Wheels)
Enkei TS9 18x8.5” +35 (21 lbs) (TS9 | Enkei Wheels)
Not exactly light, but lighter than stock. Sorry, no pics.
If anyone has a definitive yes/no on the Enkei RPF1, 17x9 +45, it would be greatly appreciated. I want to get a set for track use.
#106
Another Enkei wheel that easily clears the Brembo calipers:
Enkei TS-10 17x9” +45 (19 lbs) (TS-10 | Enkei Wheels)
#107
Volk Racing TE37 Saga, 17x8.5 +45 clears the calipers, but with only 0.5mm of clearance. Technically they clear, but that's not enough clearance, so I would say no go.
This wheel will work with at least a 3mm spacer but a 5mm spacer would be ideal. On a TL, the 5mm spacer would work great, but for those with a TSX with TL knuckles (like me)
then it really depends on how wide the tires are, but you likely will have to do some fender rolling. Below pics are with a 255/40R17 tire.
#108
Latent car nut
Received 2,005 Likes
Here is a picture of them on my car:
#109
Volk TE37 19x8” +43
Volk TE37 19x8.5" +43 (picture) 2mm clearance
volk te37 19x8.5 +43 clears with about 2mm of clearance
Attachment 120195
Volk TE37 19x8” +43
Attachment 120195
#110
added VMR V810 and TSW Nurburgring
TSW Nurburgring 18x9 +32 (20.8 lbs)
Volk TE37 19x8” +43
VMR V810 18x8.5 +35 (21.8 lbs)
Volk TE37 19x8” +43
#112
That last pic kind of looks like Milan dragway.
Euro-R_Spec_TSX (10-24-2019)
#114
Nice. Fall is the best time to go.
90foxnotch (10-23-2019)
mada51589
05-03-2022 08:54 PM
merc009
10-03-2015 12:59 AM
nuldabz
09-03-2015 05:49 PM
