List of Lightweight/Performance Wheels THAT CLEAR BREMBO CALIPERS
Old 05-04-2016, 08:18 PM
  #81
HI808's Avatar
Wondering what fitment to get for these two 5 spoke wheels will these clear the brembo??
FIVE:AD Wheels FIVE: AD R5:F Gunmetal Wheels - FIVE:AD Wheels Wheels on sale, cheap rims, cheap wheels from FIVE:AD Wheels at discount prices
varrstoen mk1 series wheels
I don't know and trying to understand about the wheel game. Thanks guys
Old 05-11-2016, 07:29 PM
  #82
Hacura's Avatar
Need your help fellas. I'm in the market for 18" Volk TE37 SL and need help with brembo clearance for the TL-S along with tires.
Here it is:
18x9 +45 - from research these should clear without a problem but may not be as concave
My questions are:
  1. Will 18x9.5 +40, +35, or +22 offsets clear? Correct me if I'm wrong: the lower the offset the deeper the concavity for these wheels.
  1. Will 18x9.5 poke? And will a 245 tire with a max stretch of 9.5" fit without requiring fender rolling?
Cheers!
Old 05-11-2016, 09:08 PM
  #83
sockr1's Avatar
Received 1,158 Likes on 909 Posts
Here it is:
My questions are:
Cheers!
my advice: offsets don't matter as much as the design of the wheel. some +30 fit, some don't.
your 18x9 +45 will most likely NOT clear brembos...EDIT: I think accuratein ran 18x9.5 +43 but i don't know if he had spacers or not
+22 will generally clear, the others depends on the wheel design
9.5 will poke if the offset is a lower number than 40 (point of reference...mine is flush and i have 18x9 +32)
9.5 and a 245 will need rolled fenders at a minimum (maybe also a camber kit for more camber or pulled fenders) if you're dropped
picking the right wheel to have the right fitment and stance takes lots of research...it took me a few months to figure out my current set and my last set of wheels
Old 05-12-2016, 12:26 AM
  #84
Hacura's Avatar
^^^Damn just when I start thinking I'm beginning to understand offsets.
So a lower + offset has a higher chance of clearing than higher + offset? I would have thought the opposite.
Seems I have to go back to the drawing board. My rear alignment is out of wack and one tire starting to show cords through the rubber.
Old 05-12-2016, 11:45 PM
  #85
iWhine
H23Accord's Avatar
Originally Posted by paperboy42190
i would like to add volk ce28 18x8.5 +40 to the list
Adding a very similar looking wheel to the CE28:
Rays Engineering A34 19x8.5 +35et (19lbs). Clears Brembos with PLENTY of room.
Old 05-13-2016, 02:54 AM
  #86
Hacura's Avatar
So for TL-S with brembos, the Volk TE37 SL in 18x9.5 with decent concavity is only attainable with the currently available +22 offset. I'm still looking into the +35 offset but from initial pics it appears more on the flat side.
Members who have ran similar specs are correct in that it will cause poke. Depending on lowering amount and tires, it will likely require fender work in the front and rear with aggressive tire stretch. Going with a staggered setup will allow for concavity in rear.
Trying to talk myself into 19" TE37 ultras in matte blue...
Old 07-05-2016, 12:13 AM
  #87
EG9ED9DC2UA7's Avatar
Attempting to revive the original spirit of the thread because I found it personally very useful and also have something to contribute now. Thanks OP for starting this, (IMHO) it remains relevant!
+1 for making it a sticky.
Tried to clean up the formatting and fix the broken links as best as I could.
Acura A-spec wheels 18x8” +45 (~30lbs)
Acura A-spec wheels 18x8.5” +45
Acura TL Type-S honeycomb/waffle wheels 17x8” +45 (~22lbs)
Advan RS 18x9” +22 (18lbs) (Picture)
Advanti Racing Deriva 18x9.5" +22 (~22lbs)
BBS Evo X MR OEM wheels 18x8.5" +38 (~18.5lb) (Pic1)(Pic2)
Enkei Kojin 17x9" +45 (~20lbs)
Enkei NT03 18x9.5” +22
Enkei NT03 18x7.5" +37 (~20lbs)
Enkei RPF-01 17x8” +35 (picture)
Enkei RPF-01 17x8.5” +40 (16.0lbs) (link)
Enkei RPF-01 17x9” +22 (16.75lbs) (picture 1 2)
Enkei RPF-01 17x9.5” +18
Enkei PF01 18x8.5” +35 (18.6 lbs)
Forgestar F14 18x9” +29 (22lbs) (picture)
Forgestar F14 19x8.5” +35
Forgestar F14 19x9” +25 (picture)
Forgestar F14 18x8.5” +33 (19lbs 15.5 oz)
Forgestar F14 18x8.5” +26 (20 lbs 1oz)
MSR Series 045 18x8” +35 (21.9 lbs)
Prodrive GC-05F Monoblock 18x9.5” +22 (18lbs)
Racing Hart CP-035 17x8” +38 (will fit with 10mm spacers) (13.9 lbs)
Rays Engineering A34 19x8.5” +35 (19lbs).
Rays Engineering 57F 18x8.5" +45 (~17lbs)
SSR Type F 19x8.5” +42 (19.7 lb)
Volk CE28 18x8.5” +40
Volk TE37SL 18x9.5” +22 (18lbs)
Volk TE37/LE37T 19x9.5” +35
Volk TE37 19x8” +43
Volk RE30 18x9.5” +35
Weds Sport SA-70 17x9” +35 (picture)
Work VS-XX 19x9.5” +28 (picture)
Lightweight but no offsets so not sure which offset works
5Zigen Beckets FN-01R 17x8” (14.70lb)
Buddy Club P1 Racing QF 17x8” (13.60lb)
Motegi Racing Trak Lite 2 17x8” (14.60lb)
Motegi Racing Trak Lite 17x8” (15.00lb)
Racing Sparco LE 17x8” (14.60lb)
SSR Type-C (called Competitions in the US) 17x8” (14.30lb)
SSR Type-C (called Competitions in the US) 17x8.5” (15.00lb)
Wed's TC-005 17x8” (14.90lb)
Wed's TC-105N 17x8” (14.90lb)
Unverified suggestions that may work (wheels designed for BBKs)
Enkei GTC-01 18x8" +45 (20.6lb)
Enkei OEM Nissan 350Z Track V.1 F 18x8" +30 (18.2lb) / R 18x8.5" +33 (18.6lb)
Tirerack.com search, specific to Type S
Rules and Legend:
If you are unsure of the weight of the wheel, please highlight the weight in Red font and hopefully someone on here who knows the actual weight will come and correct it.
Wheels that do not clear the Brembos will be highlighted in Purple font. This information will be useful to perspective buyers so that they know what size they can not fit.
Also, lets keep this list in alphabetical order in the case that this list becomes rather large. It will make the information on here a heck-of-a-lot easier to find.
HYPERLINK pictures, don't post photos on the list.
Old 09-10-2016, 01:29 PM
  #88
ReDevil
r3devi7's Avatar
Volk TE37 19x8” +43
Rules and Legend:
18x8.5+40 TE37 clear, 18x8.5+40 SE37k clear, RPF-1 17x9.5+38 do not. Will update with pics when I'm at my desktop later.
Old 09-20-2016, 04:53 PM
  #89
GOOSEej's Avatar
Does anyone know if Cosmis Racing MRII 18x8.5 +22 will clear ??
Old 09-22-2016, 11:44 AM
  #90
GOOSEej's Avatar
Cosmis Racing / MRII / 18x8.5 / +22 / 22lbs / Brembo Clearance Story by GOOSEej | Photobucket
I will upload pictures of wheel and the caliper to the album.. This was just a acquaintance car
Old 11-05-2016, 03:28 PM
  #91
jimmyfu's Avatar
Confirmed:
Enkei / Evo X GSR (Stock) / 18x8 / +38 / ??? /
Old 02-11-2017, 05:42 PM
  #92
Francis-david Crete's Avatar
I have a set of Sparco Crimson 17x8 et38 and they clear the RL calipers on my 7th gen Accord. Just needed 90° tire valve.
so they will clear the brembo as well !
Old 02-12-2017, 02:53 PM
  #93
RPF1+RS3 FTW
AnthraciteAspec's Avatar
Originally Posted by GOOSEej
Cosmis Racing / MRII / 18x8.5 / +22 / 22lbs / Brembo Clearance Story by GOOSEej Photobucket
Wow that is a tight fit lol
Old 06-16-2017, 01:40 PM
  #94
Le7316's Avatar
Volk TE37 19x8” +43
F1R FF2718855120114335731GM 18x8.5 +35 ( weight unsure) 5x114.3 & 5x120
Rules and Legend:
Old 06-16-2017, 11:13 PM
  #95
DogP's Avatar
I just purchased a 2008 TL Type S with aftermarket rims already installed. From the pics, they appear to be Drag DR31 ( http://www.dragwheels.com/product.php?id=166 ). The previous owner installed factory size tires, but unfortunately I don't know the specs of the wheels (I assume 17x8, and probably +47, since it's closer to the OEM than the +35 option, but can't say for sure). I can measure them and update once I take them off. Added to the "no offsets" list below, pics here: Imgur: The most awesome images on the Internet .
Volk TE37 19x8” +43
Drag DR31 17" (unsure of width and offset) (21lb for 17x8) (Pictures)
Rules and Legend:
Old 06-18-2017, 11:28 AM
  #96
llllBULLSEYE's Avatar
Miro 398 18x9.5 +20 (22.0lbs)
miro 398 19x9.5 +20 (24.0lbs)
Old 06-23-2017, 08:35 AM
  #97
Steelhead 6.2's Avatar
Very helpful, but I wish there were pics to go along with the the list of wheels that clear!! just a little lazy! Ha!
Old 09-11-2017, 07:02 PM
  #98
treal512's Avatar
Ugh, I'm starting to hate these Brembos!!!
(can't find wheels I want that fit)
Edit: Anyone know if Enkei RPF1 in 18x9 +35 clear?
Old 09-13-2017, 09:35 AM
  #99
sockr1's Avatar
enkei will be able to tell you
Old 09-27-2017, 10:43 AM
  #100
7th Gear
dw6484's Avatar
I've been looking for this information for my wife's TL. Thanks to the OP for posting.
Old 10-13-2017, 10:02 AM
  #101
Volk TE37 19x8” +43
Konig Milligram 18x8.5 +35 18.5lbs
Old 11-08-2017, 10:56 AM
  #102
wilspainar's Avatar
Does anyone know if the Enkei RS05RR wheel 18x10 wheels fit over the Brembo's? Specifically the 22mm offset.
Old 12-21-2017, 07:36 PM
  #103
BigTurkey's Avatar
Enkei RPF1 17x9 +22
Just got these put on my TypeS. Enkei RPF1 17x9 +22 with 255/40 r17 tires on them. Huge improvement over the base wheels and worn tires I had before. Posting in case anyone is looking for pics with wide tires.
Attached Thumbnails List of Lightweight/Performance Wheels THAT CLEAR BREMBO CALIPERS-img_3707.jpg   List of Lightweight/Performance Wheels THAT CLEAR BREMBO CALIPERS-img_3703.jpg
Old 02-01-2018, 11:49 AM
  #104
Brock
Euro-R_Spec_TSX's Avatar
These Enkei wheels easily clear the Brembo calipers:
Enkei TX5 17x9” +45 (20 lbs) (TX5 | Enkei Wheels)
Enkei TS9 18x8.5” +35 (21 lbs) (TS9 | Enkei Wheels)
Not exactly light, but lighter than stock. Sorry, no pics.
If anyone has a definitive yes/no on the Enkei RPF1, 17x9 +45, it would be greatly appreciated. I want to get a set for track use.
Old 03-25-2018, 09:20 PM
  #105
nhizzat's Avatar
Wheel: Enkei RC-T4
Weight: 19.6 lbs
Easily clear Brembos and don't rub anywhere even with 245/40/18s.
Old 08-17-2018, 07:12 PM
  #106
Brock
Another Enkei wheel that easily clears the Brembo calipers:
Enkei TS-10 17x9” +45 (19 lbs) (TS-10 | Enkei Wheels)
Old 09-08-2018, 12:55 PM
  #107
Brock
Volk Racing TE37 Saga, 17x8.5 +45 clears the calipers, but with only 0.5mm of clearance. Technically they clear, but that's not enough clearance, so I would say no go.
This wheel will work with at least a 3mm spacer but a 5mm spacer would be ideal. On a TL, the 5mm spacer would work great, but for those with a TSX with TL knuckles (like me)
then it really depends on how wide the tires are, but you likely will have to do some fender rolling. Below pics are with a 255/40R17 tire.
Old 09-08-2018, 01:13 PM
  #108
Latent car nut
horseshoez's Avatar
Received 2,005 Likes on 1,407 Posts
Originally Posted by Q_ShipTL
I know they won't clear Brembos, but does anyone know how much the 04-06 Base wheels weigh vs the 07-08 Base wheels?
What do you mean they won't clear the Brembos? All 2004-2006 TLs came with the same wheels regardless of whether they had Brembo brakes or not.
Here is a picture of them on my car:
Old 11-24-2018, 04:51 PM
  #109
DesertMistTL's Avatar
Volk TE37 19x8” +43
Volk TE37 19x8.5" +43 (picture) 2mm clearance
volk te37 19x8.5 +43 clears with about 2mm of clearance
Attachment 120195
Old 11-29-2018, 10:36 AM
  #110
sockr1's Avatar
added VMR V810 and TSW Nurburgring
TSW Nurburgring 18x9 +32 (20.8 lbs)
Volk TE37 19x8” +43
VMR V810 18x8.5 +35 (21.8 lbs)
Old 10-22-2019, 02:56 PM
  #111
90foxnotch's Avatar
Enkei RP03 18x8.5 +35 just under 20lbs
Old 10-22-2019, 06:35 PM
  #112
Brock
That last pic kind of looks like Milan dragway.
Old 10-22-2019, 06:58 PM
  #113
90foxnotch's Avatar
Hahaha great eye man. It is! Got the new wheels on Friday night and I took it down the track Saturday. Old girl ran a 13.9 @ 100
Euro-R_Spec_TSX (10-24-2019)
Old 10-22-2019, 08:07 PM
  #114
Brock
Nice. Fall is the best time to go.
90foxnotch (10-23-2019)
Old 08-12-2020, 09:42 PM
  #115
BigTurkey's Avatar
bump
mada51589
05-03-2022 08:54 PM
HairyMonkey019
04-22-2016 10:50 PM
merc009
10-03-2015 12:59 AM
HOWELLiNC
09-10-2015 01:39 PM
nuldabz
09-03-2015 05:49 PM
Quick Reply: List of Lightweight/Performance Wheels THAT CLEAR BREMBO CALIPERS
