Konis with S.tech springs problem
I just install Konis with S.tech springs and the gap between the tire and the fender is like stock, i don't understand, s tech spring is set for 1,4 inch and the car seem to have no drop..... the mecanic guy said that he set the koni at the lower point... can somebody help me
Former Sponsor
I would check a few things:
1. Perch - most likely installed upside down
2. Springs - did you put the right ones on in the front and the right in the rear? Although this is unlikely it is possible; your front would probably sag while your rear would be high up.
3. Are you sure it's not lower or not as low as you want? Did you take a measurement? You are still going to have some wheel gap as it's only about a 1.3" drop.
U cannot adjust the Spring...
wat u could adjust is the setting on the Koni Yellows, from Soft to Stiff usin the knobs they sent u in the box.
No.
The only way to change the height of the car with Koni's is to lower actual the perch on the shock. Not sure if that requires complete disassembly or not, but it might.
cycdaniel
Dec 17, 2019 10:58 AM
jmoney2001
Aug 12, 2019 06:23 PM
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
