I want the Brembo Look. Please help...
I am basically ignorant when it comes to this topic, but I was at an Acura dealership last week and saw that a Manual TL (Aspec) had brake assemblies different than mine. I REALLY liked the look with the Black assembly and Acura decal. My brake assembly is just a flat metal. THe parts guy told me those were Brembo brake assemblies installed on the manual's only. Is this really the case b/c I was under the impression my automatic had upgraded brakes as well?
Is there anything aftermaket that will give me the look without having to drop the $ for all the necesary parts for the Brembo's?
yes the 6mt has brembo's i believe they are .2 inches bigger in the front, the back i know is the same. Im not sure wear to upgrade because ur not going to get much out of your old brakes.
You won't be able to get the OEM braking system on your 5AT TL... However you can go aftermarket and it will give you the performace and look.
There is a Brembo aftermarket kit for the automatic TL, which is about $2000-$3000 (can be found on www.comptechusa.com and www.tirerack.com)
Rotora is another company that also makes a kit for the automatic TL, I am not sure on the price. www.rotora.com
Stoptech is your 3rd choice, I know it was in development, but it may be done by now and ready to order. www.stoptech.com
Some of these sites may not have the 3rd Gen TL listed, but you can call them and they can give you the information on the product and their part numbers.
There are BBK available but you're gonna shell out a l'il bit of $$. Click here to get an idea of cost. You might wanna check ebay also or shop around online for possibly better deals. One of the members got a kit (Jatt) but I don't remember the cost. As far as the Aspec is concerned, you have the upgraded pads. They work just as well stopping the car and much less brake dust than Brembos. Another option would be to paint your calipers which a number of members have done. Do a search on this.
Shift_faster
stoptech kit is gonna probably come in at around 1700-1800 judging by the price of the previous gen TL. i would go with the stoptech if available they make some awesome brakes kits.
CEO, Team Anthracite
Do you know what sort of "upgraded pads" the A-Spec kit comes with? I'd be interested in finding out whether it's something I can easily buy aftermarket.
Registered VTEC junkie
Brembos are cool but I don't like all the brake dust. It's just too much. Does anyone know of any brake pads that have less brake dust than the stock ones?
Originally Posted by cTLgo
Originally Posted by caball88
yeah i figured they had a kit already, if i was shopping for a kit i would definitely get these over the brembo and the rotoras. stoptech's are known for their performance just like brembo. but at 1800 vs 2300 i would choose the stoptech over the brembos. for the extra 4-5 hundred over the rotoras i would go with the stoptechs again because of proven performance. there was a huge thread before explaining the differences in kits between the rotora, brembo and stoptech brakes.
I contacted Acura of Las Vegas, after seeing an add from them on Ebay. They quoted $950.00 SHIPPED for the complete factory 6sp Brembo front setup. They said it is a common upgrade and the only thing I would have to do is get the larger spare tire to fit over the larger brakes. Planning on ordering this system next week.
VTEC HoooA
Anyone?
Shift_faster
Big brake kits from 3rd party companies such as Rotora, Stop Tech and Brembo start at about $1500. Click here to see how much Brembo BBK cost. This is what is included with the Brembos.
Kits are front-only system with one or two-piece (2 pc are noted) cross-drilled vented discs or slotted with anti-corrosive cadmium plating. Mounts floating style to vehicle specific billet aluminum bell. Brembo engineered and machined two-piece cast aluminum caliper. itted with four sequentially sized aluminum pistons, dusts seals and anti-rattle clip. Also included, complete axel set of high performance pads and DOT/TÜ approved stainless steel brake lines. Aircraft quality mounting brackets and hardware complete this system. All Brembo high performance brake systems are ABS compatible and retain the stock master cylinder.
Acura604
2G RDX Photograph Gallery
17
02-08-2021 03:32 PM
jmoney2001
09-11-2015 12:07 PM
