HT-Spec Height Adjustment Reference Thread!
#41
Chapter Leader (Central Florida)
^^^please keep in mind there are a number of variables that will change what the CtC spacing actually means in ride height. A Type-S with an Auto (aka Heavy) and a Base with a manual (aka less heavy) will ride at different heights with the same CtC
#42
COILOVER TYPE: Type II (V1)
FRONT
CtC Spacing - 4-5/8"
Wheel Gap - 1 finger gap
Damper Clicks - 20 from the LO side
REAR
CtC Spacing - 4.5"
Wheel Gap - Little Less Than 1 Finger
Damper Clicks - 10 from the LO side
RIDE QUALITY- Front feels really good and comfortable for daily driving. May adjust to 25 for some better handling. The Rear are a little too firm for me at 10. Lower back is kind of killing me. May drop to 5 or Full Soft.
FRONT
REAR
CtC Spacing - 4.5"
The following 2 users liked this post by faceman1:
DeathMetal (09-19-2011),
JD TL-S (12-16-2011)
#46
COILOVER TYPE: I, Version 2
FRONT
CtC Spacing - N/A - have to check
Wheel Gap - just on top of tire
REAR
Wheel Gap - a bit over rear tire
RIDE QUALITY - the way I wanted it. firm without being very bouncy. Marcus did the install and he actually has the notes as to what my setup was measured at. absorbs the bumps real good and doesnt transmit the impacts into the cabin.
FRONT
REAR
#47
#48
I'm getting ready to get the HT-Spec v2 Type 1 on my TL-S and need some clarification please. If you look at the following link from Marcus' write up about coilover adjustments:
http://heeltoeauto.com/files/tech/HT...ment%20Doc.pdf
Would the collar to collar be the "Lower Bracket Height" as noted on page 4 of the document?
Gonna get started on the install tommorrow or sometime this weekend and any comment/help would be much appreciated. Hopefully it doesn't take me the whole weekend since I have a J-Pipe to install also!
Thanks!
Thanks!
#50
FRONT
REAR
CtC Spacing - 4.5"
FRONT
REAR
CtC Spacing - 4.5"
#54
COILOVER TYPE II (V2)
FRONT
CtC Spacing - 4"
Wheel Gap - no gap, tires half tucked
Damper Clicks - did not adjust yet (whatever they came set to)
REAR
CtC Spacing - 4"
it defintiely needs to be set firmer, idk if they were in the middle when i put them on, or if they were all the way low... and there is a breakin period for sure... the difference in one day was very noticable...
FRONT
CtC Spacing - 4"
REAR
CtC Spacing - 4"
#55
Wheels are Axis Pentagons. 19". I just ordered the V2 damper upgrade from Heeltoe. I'm hoping for better ride quality/handling. Couldnt get the V1's to feel "right". I currenty have the V1's set to 25 front and full soft in the rear. Front is a lil bouncy at times and I really don't like having the rears on full soft. Hence the reason for upgrading to version 2.
#57
preciate that faceman!! question for everyone... did everybody just twist em to all the way soft and then start counting clicks? like i said before, i didnt mess with the dampening when i installed it, and its pretty soft now... i went and looked at the backs real quick (seat is still off) and it twisted both ways which makes me think it might be in the middle somewhere...idk... i'll mess with it today when i get off and report back...
also, my 4 inches was from the bottom of the spring holder rings where we all measured from to the red cup twisty thing, not to the ring sitting on top of it where everybody else measured to, so mines really 4 inches minus the thickness of the ring just to clear it up... not a big difference, but hopefully that wasnt too confusing..
#58
... question...
for the front coils, (v2 type 2) i'm tryina adjust the dampening, but the knob and the lil gold piece with a bunch of holes its connected to aare both loose and dont click... i can spin them independently as well... am i supposed to tighten the gold piece with the holes independently of the red wheel and then adjust the red wheel? or keep em both loose, twist the red knob all the way lose then start counting clicks then tighten it down with the gold thing?
it doesnt seem to click or when the gold part is tightened... idk if that made any sense at all but hopefully somebody can help me out... also put a email out to marcus at HT, but figured id share this in case somebody else was confused... the backs seemed to twist just fine, but i didnt really mess with those yet... thanks everyone for the heads up!!
#59
Yeah. Tighten the gold piece with the holes with a pliers. Just make it snug. Don't over tighten. If you get no clicks or it just spins after doing that your knob may be bad.
I never got a "positive" click when turning mine towards the Hi or firm side but could feel the clicks when making the damper softer.
#61
I took the recommended settings from Heeltoe and went a little lower. I haven't adjusted it. Just installed it and loved the height it's at.
COILOVER TYPE: Type 1
FRONT
Preload - 8"
CtC Spacing - 3 3/4"
Damper Clicks - N/A
REAR
Preload - 8 3/4"
CtC Spacing - 4 1/2"
Damper Clicks - N/A
Ride Quality - Firm on decent streets. Pretty harsh going over bumps. Uncomfortable at times but it's a good solid feel imo. Passengers probably won't like it.
FRONT
Preload - 8"
Damper Clicks - N/A
REAR
Preload - 8 3/4"
Damper Clicks - N/A
#64
Marcus revised those settings. Preload should be 7.5 inches not 8. Out of the box they are 8in. I too noticed the ridiculous banging when hitting any average size bump. Shock is bottoming out. Marcus said making that 1/2in preload adjust will significantly help. I'm in the garage adjusting that now.
#66
#67
iWhine
Interesting. So did you notice a softer ride after adjustment? For some reason it seems to me raising the preload that 1/2 inch to a total of 7.5inches instead of the claimed 8 would make the ride firmer thus keeping you from bottoming out. Please clarify your results as maybe I'm over thinking this and confusing myself
#68
Never thought of checking eBay. If I can pick up a set for $800, I'll be happy.
#69
#70
09-17-2015 09:01 PM
09-14-2015 10:48 AM
