How much torque do you use for your wheels ?
Hi folks !
I'm wondering how much torque do you set up when you tight up your nut's wheel ? Acura recomment 80 pounds (for the spare tire at least, no emntion about the regular wheels), but I find that not enough personnaly.....I'm almost affraid to loose a wheel !
Any idea ?
Any idea ?
80 lb-ft is all you need! I hear you on how it "doesn't feel like enough", but that's because you have such a long lever arm with the torque wrench.
So, you're all set with 80!
BTW, most Toyotas and Hondas are between mid 70's and mid 80's. For instance, my Lexus GX requires 83 on 6 bolts.
Many Germans, which use bolts instead of lug nuts, require as much as 110 lb-ft.
Originally Posted by bluenose
Service manual calls for 85 ft lbs
Anyway, 80 or 85 does'nt make any difference...
From the 2004 TL Service Manual:
Front: 79.6 ft lbs, 108 N-m, 11.0 kgf-m, Service Manual pg 19-17
Rear: 80 ft lbs, 108 N-m, 11 kgf-m, Service Manual pg 19-28
Aaaarrrggghhhh!
Originally Posted by Jesstzn
Boy thats quite a spread between the front and rears .. .4 ft lb .. Got to love Japanese precission .. lol I have a good torque wrench .. but not that good.
orkoTL
4G TL Problems & Fixes
107
09-28-2017 09:12 AM
09-14-2015 10:48 AM
