How many miles did you get on your original tires?
I have a 2006 Auto TL with 36K miles on it. I think it's about time to change the tires.
Thinking about Continental DWS or Yokohama Advan S4. (all season for me)
Please share when you replaced the first original tires (I have Bridgestone Turanza), and with which tires? Thanks!
it's a car-drive it
Registered but harmless
Received 1,102 Likes
They were replaced with the Advan S4s, which now have about 7K miles on them. The Advans have more dry traction than the MXM4s after both are broken in, and the Advans seemed more predictable at the limit. The Advans seem slightly noisier on concrete surfaces and quieter on asphalt than the MXM4s; I didn't notice any difference in steering response, gas mileage or wet traction.
The other tires I considered were the Bridgestone Pole Position 960, Michelin Pilot Sport A/S and Pilot Sport PS2 (summer tire in SoCal ).
On a side note, the Turanza EL42 (original tires) are really that bad? I only got 36K, may be another 1000, but that's it. Anybody else run on Turanza EL42? The reviews are obvioulsy really bad.
My 2006 TL Nav has 92,000 Km (57K miles) on the OEM Michelin tires. I will need new ones sometime this year if I don't trade the car. Will be looking for a tire that is quieter and maybe a bit less harsh on rough surfaces. I'm having a real problem finding any 2010 that I like better than my '06 TL.
I changed out two fronts from flats early on, but got 63.5k out of a pair of the Michelins. Picked up some Falkens that are better in rain, but much worse in snow.
Personally I think the traction is much better and I can't really tell much of a difference when the roads are wet, and they are fairly quiet too.
The Advan S4 is NOT an all season tire. While I think the rubber compound is just wrong, it may be that it's wrong for cooler climates, from some of the comments I see on tirerack.com. Perhaps the summer rain in Toronto isn't as hot as rain in other places, and maybe I'm just not getting enough heat into the tires in the dry...
VSA on or off, the S4's don't work in any depth of snow, for starting, stopping (ha, ha), climbing hills, or turning. Wet traction for starting, stopping, and cornering might have been OK, but quickly deteriorated, although hydroplane resistance was excellent until a uniform 5/32 (50%) of tread depth.
Hookup for quick starts in the dry wasn't what I'd hoped for, but I can definately feel more body lean in corners, so I'd say they have more grip than the MXM4's. The S4's have worn well, but I'm junking then with 5/32" of tread left; I might try to find a track day first, though - if it's going to be dry. I thought turn-in was slow, in the dry, but more pressure (38F:36R) helps, at the expense of ride comfort.
Note that the weight of a 225/50-17 Advan S4 is about two lbs heavier than the same size Continental Extreme Contact DWS (about 26lbs vs 24lbs); tirerack.com appears to have an incorrect tire weight for this size (22lbs), if you compare that info with Continental's website (24lbs).
I've already decided on the DWS, and am just waiting for the spring. We drive a lot, and the S4 is just such a gamble for a temperate climate. The S4 also costs a third more than the DWS.
cycdaniel
12-17-2019 10:58 AM
Zonian22
11-14-2015 01:20 PM
Zonian22
09-02-2015 08:19 AM
