Good spring/shock set up for what im looking for?
My shocks are going bad so time to get knew ones. (2005 TL)
Thinking of instead of just getting stock springs and shocks again that ill go with a mild drop.
Eibach Pro springs and Koni yellow setup is that good and how much does it run? She sits like this now
great setup and a mild drop would be the Aspec suspension.
ResistaNce (08-17-2012)
Just had my s techs installed on stock shocks. rides fine, occasional bumps. but its not horrendous. eventually ill get koni yellow shocks or the Tein coilovers. but the springs not hard to install just take you time. and the back seat it a bitch to take out. but other than theres not many surprises unless you get a rusted bolt. THEN YOURE FUCKED.
If you search you'll find justinspace pics of Koni + Aspec. I think he's on the lowest shock perch too.
I just installed Koni yellow + Tein H Tech. Its almost as low (lowest Koni perch) as my H&R coilovers, and it rides just a little more stiff than stock/TL-S. Overall the ride is much more comfy than the coilover kit too.
justnspace (08-20-2012)
1fatcrxnem1
22
06-01-2018 01:23 AM
nanos
11-12-2015 08:41 PM
braveheart
09-07-2015 08:12 AM
