Front to bacK??
Front to bacK??
SO I searched and found not one answer on this issue, did you ( when and if you had the Turanzas long enough ) rotate them front to back or RF to LR / RR to LF...and at how many miles??..thanks
My Turanzas, when I had them, went front to back and tried to do it every 5K miles. Still only lasted 16K miles before going to the Michelin Pilot Sport A/S. Pricey but they instill a lot of confidence that the Turanzas didn't.
I rotated mine once before I got new wheels...did it the old fashioned way...F > R (straight back), cross the R's and put them in the F. If you follow that pattern (or the reverse of it), each wheel will eventually end up at each corner of the car (after 3 rotations with the same pattern; the 4th puts it back where it was originally). The same pattern is in the manual for regular tires (HPT's, ie. directional tires, are straight F > R and R > F).
Thanks guys I have allways done front to back but was confused on one thread that I can't locate at the moments that it was a must to go from FL to RR etc so I had to ask.....thanks I will do that soon
Marmbo
4G TL Problems & Fixes
Sep 21, 2015 09:39 AM
nuldabz
Sep 3, 2015 05:49 PM
