Few questions about me having 19's
I have a few questions regarding the fact that I run 19" wheels (which I love and never had any issues with).
1. Is my speedometer is 'off' by a little since it's calibrated on stock 18's? or am I wrong about this? (I'm not sure where the speed 'sensor' is located on our cars, so I'm not sure if wheel size affects it at all) If I am correct does anyone has a guesstimate on about how much it is off by?
2. In the unfortunate case that I get a flat, would it be ok to use my spare? (which is obviously a much smaller wheel )
the rolling diameter should be the same, unless you went with a higher or lower tire.
the stock tire size is 235/45/17 and if you head to http://www.1010tires.com/Tools/Tire-Size-Calculator
you can compare and contrast your tire size. it will even give you how much you are off by.
since the fronts are the driving wheels, I would never put the spare on the front and have two different sized wheels.
whoismiked (08-07-2013)
Type-S wheels are 17's.
the Aspec rims are the only "stock" rims that are 18s. but with the correct sized rubbers its the same rolling diameter as the 17s and your 19s.
i'm surprised you picked the right sized tire. did you have help putting together your wheels and tires?
A shop guy who knew what he was doing, that's sort of rare, haha.
I didn't do any calculations (like he must have) but I did set my stock wheels next to the new ones (both had the rubber on them obviously lol) before he mounted them and they were pretty much the same
Anyways, thanks a million J
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
