Eibach Vs Comtech
Old Jan 29, 2008 | 01:11 AM
chris80i's Avatar
WEAKSAUCE !!!
Red face Eibach Vs Comtech
ONE INCH SPRINGS EIBACH VS COMTECH
I am looking to get some spring setup for my TL-S. I am wondering which product has a better qaulity and will i need a camber kit with this 1 inch drop. I have delt with camber kit's in the past and they become very sqeaky/noisy after install. I just spoke with a local dealership here in Cali, Bay Area and the dealer tech said it would be ok to install w/out voiding my warrenty.... Any suggestions? I am also thinking to do the Rear Sway Bar and curious how much stiffer the car will be with these two modificaitons. I don't want to have my ride too harsh after deciding not do deal with coilovers. I have also heard the TL-S with Teins SS at the softest settings is not so bad as well. Any information would be helpfull from people who have suspension upgrades thanks...
Old Jan 29, 2008 | 01:34 AM
Bearcat94's Avatar
AZ Community Team
I've read here that the Comptech springs are made by Eibach. I don't know if that is true or not. Assuming it is, there should be no build quality differences.
In general, the smaller the drop the less additional negative camber you'll have. A 1" drop from After Market springs is about as small a drop as you can find. Here's a good read on the need for Camber Kits:
https://acurazine.com/forums/car-talk-5/motorcycle-vin-check-147290/
You say the "dealer tech" told you that you'd still be under warranty. Taken literally, I doubt that a "tech" has much say on warranty coverage. If the Service Manager said that, it'd have more weight.
Old Jan 29, 2008 | 01:43 AM
chris80i's Avatar
WEAKSAUCE !!!
Yeah the the master tech at this acura said it will be ok b/c i have extended warrenty nothening to worry about, he said they have had comtech supercharged tl's dropped acura's always go there w/out any problems... Yeah i am still thinking to just get a 1inch springs drop with oem shocks between these two springs, or possible save more for tein ss , does anyone know the min drop can you have with the tein ss? can i drop it only 1inch maybe no more then 1.5 thank for the help/advise. oh yah i this dealer is pretty ok about modifications and said ask them what can i do and can't do. They are ok with comtech for sure. Tein SS adj to near OE ride comfort do ok by anychance? i don't want to kill my ride...
Old Jan 29, 2008 | 01:51 AM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
It depends on which Comptech springs you get. If they are brand new, then just like Bear mentioned, the Comptechs are just rebadged Eibachs, so you are pretty much in the clear. If the Comptech springs are older ones, be careful. They have a tendency to make your car sag in the rear. The "bad batch" Comptech springs are usually grey in color. The new, rebadged Eibach springs are either black or dark blue.
To be totally sure of what you get, just get the Eibachs, since then you know for sure what you're getting, and they're the exact same thing anyway.
Old Jan 29, 2008 | 06:11 AM
BrianC636's Avatar
That's just my luck. Those are the ones Excellerate sold me that are sitting in the attic waiting on me to order the Koni SP3's.
Old Jan 29, 2008 | 11:31 AM
chris80i's Avatar
WEAKSAUCE !!!
luck
oh wow, i just sent him a pm reguarding those springs and ill see what he has to say about what kind of springs he will send over....i hope he has the good batch now
Old Jan 29, 2008 | 11:45 AM
Excelerate's Avatar
Former Sponsor
Just to clarify Eibach always made Comptech's springs for the 3rd gen TL. The older springs for the 2nd gen CL/TL from a long time ago were made from someone else, and those were generally a light silver silver color. Comptech hasn't been using that vendor for a long time.
Old Jan 29, 2008 | 05:42 PM
chris80i's Avatar
WEAKSAUCE !!!
So anyone else prefer Eibach over Comtech springs ? or Comtech over Eibach? Thanks...
Old Jan 29, 2008 | 05:43 PM
chris80i's Avatar
WEAKSAUCE !!!
Spring Selection
Old Jan 29, 2008 | 07:00 PM
subbuzz's Avatar
07 tl-s in
the comtpech springs I got were a light silver what color are the new eibach comptech's?
I got comptech on the tl and had 2 set's of eibach(prokit & sportlines) on my cl and it's basically the same shit. The prokit rode just like my tl (nice) when I put sportlines on (lower drop/different setup) the ride suffered abit..........
Old Jan 29, 2008 | 09:18 PM
chris80i's Avatar
WEAKSAUCE !!!
I went to the CT comtech new site and they said the springs where $99?
Old Feb 2, 2008 | 02:00 PM
Japspec954's Avatar
yea, dosent seem to make any sense. Eibach springs are like 200 plus right? so why are the comptechs only 99?
Old Feb 7, 2008 | 03:08 PM
Conor's Avatar
Excelerate I need your help.
Do I have to worry about silver comptechs that are on my TL right now. Just had them installed with a 19x8.5 and 245/35 and am rubbing pretty bad with any weight in the back seat. Someone on herer told me the silver springs are defective and sag in the back which might be causing it. I know that you know what you are talking about. Is this the case? Should I put new springs on before I try rolling the fenders?
Old Feb 7, 2008 | 08:08 PM
Excelerate's Avatar
Former Sponsor
B/c Comptech is getting out the spring market and is liquidating their spring inventory.
Old Feb 7, 2008 | 08:09 PM
Excelerate's Avatar
Former Sponsor
As I said above:
The 3rd gen TL springs never had a problem. You likely have too wide of a tire or a wheel with an aggressive offset.
Old Feb 7, 2008 | 08:37 PM
sifuacura's Avatar
There's alot of asian in
wow i have the same set up tires/rims as u..and i just installed the spring. one of the tech said that my back look lower than my front..i haven't put any weight on the back yet to see if it rub..hope it doesnt...
Old Feb 7, 2008 | 08:57 PM
subbuzz's Avatar
07 tl-s in
I don't think the back is actually lower, it just appears that way due to the fact you have more wheelwell in front. I wish my front looked like my rear based on wheel well.
emailnatec
29
Sep 28, 2018 04:27 PM
Onyxthecat
Oct 18, 2016 02:05 PM
mmhdavid
ILX Tires, Wheels & Suspension
Nov 9, 2015 11:18 PM
TSX 09
33
Oct 25, 2015 01:32 AM
TSX 09
Sep 10, 2015 10:21 AM
