Eibach Pro Kit Springs... Questions!
Just picked up a set of type s wheels for my 07 TL tech. I am going to lower it with the eibach pro kit but I have a couple of questions before doing so...
Will I need a camber kit?
Have people had problems with blown shocks even with the 1"-1.4" drop?
Should I expect issues? Or are ppl for the most part smooth sailing?
The car currently has 36k miles on it.
I am dropping for the sole reason of looks and having a nicer stance
I really dont wanna drop $1200+ on coilovers, this is my DD and I just want it to have a lil more unique ride and driving quality. Dont want to end up fixing everything after a 1" drop.
Thanks!
Thanks!
i wouldn't go with eibachs, personally.
i had them on my type-s and they really don't lower it enough to make the install worthwhile. look into tein h-techs or h&r sport springs if you don't want coilovers.
coils don't cost $1200+ either, i got my megans for under $700 (used)
Can anyone answer any of my questions with a supporting deposition lol...
minimum drop with coilovers? you can set it any height you want. if you want 1-1.5"...then go for it.
will you need a camber kit? i don't know, it all depends on where your camber/toe specs are after you alter your suspension. get an alignment after you lower the car and go from there.
blown shocks? no...you're fine at 36k miles.
what type of issues concern you?
For your reference:
[IMG][/IMG]
Pro-Kit with Ingalls rear camber kit. Yes, I'm aware of the sagging look but as of today no complaint with the ride and look, maybe I got use to it. Good luck with your decision.
[IMG][/IMG]
Former Sponsor
http://store.excelerateperformance.c...5/i-60220.aspx
You need a qty of 2 to complete the rear of a car. We have this and the springs in stock.
Eibach makes a great set of springs. It's a 1" drop; reasonable, good quality, similar ride comfort to the factory springs. Most 3rd gen TL's have negative camber from the factory. It's a good idea to install the rear camber kit too. I'd recommend the Ingalls kit because it includes an arm for toe and for camber.
I know this is a bit late as far as response, but hopefully this may help you. I added a Pro kit about 5 months ago. As has already been stated, TL's tend to run negative camber anyway, so once my Pro Kit was added, my negative camber was pushing -2.5 and -3. I also had new wheels/tires put on at the same time and didn't feel like ruining the new rubber, so I opted for SPC rear camber kit. After approximately five months, everything is still fine. There is one issue that is well known: After the springs go through their "break-in" period, you may start getting some clicking noise...almost sounds like your rear struts are shot. I also had new aftermarket struts added during my conversion, so I know it wasn't the struts. Come to find out, the springs are so tight at the top that they are causing the clicking noise. You can contact Eibach directly and have them send you some coil "split tubing." Acura also makes these, though they are like $7 each (Eibach sent them free of charge). I added 3 sets of split tubing to the rear of each spring and the noise was immediately gone. Jack up the car, remove tire, and place the tubing as high as you can get it. After my springs settled, I was at approximately a 1.4 drop...front and rear.
make sure you post some pics of your TL after you "lower it" on eibach springs. i'm eager to see them.
CLtotheTL32 (12-21-2011)
^ you're so fucking cool!! Hey everybody, don't disagree with this guy!! He's got some totally unwarranted sarcastic and wayyyy funny jokes and told ya so's in the holster! Watch out!!
Zonian22
11-14-2015 01:20 PM
Zonian22
09-02-2015 08:19 AM
