Disabling TPMS
Disabling TPMS
Has anyone looked at disbling the tpms in the 06 model ... eg a fuse pull or something. I'm looking at aftermarket wheels and don't want to deal with swapping valve stems or having a warning light on all the time .
TYIA
TYIA
This has been talked about before. No it's not possible. If you want to learn more I suggest a search.
Why not buy sensors and have them installed in your aftermarket wheels (also been discussed in the tire/wheel forum).
Gee I am glad they moved this thread where no one looks ...
Bump for some info .. Someone must have thought of this or tried it.
CTS-V Import Slayer
He just doesnt want to do the work and hand feed you, thats all.....but here ya go man....but again.....you could have done this yourself?
https://acurazine.com/forums/search.php?searchid=257640
Originally Posted by ililillilillilil
if u can afford a TL with rims u can afford to do things the right way and not nigga-rig it
Maybe the rims I am looking at won't accept the sensors ... and I did do a search TY and didn't come up with the answer I was looking for .. If I knew for sure the sensors would fit I'd do it .. Any one of you kind and helpful souls have a picture of the part of the sensor that goes in the inside of the rim? Is it much bigger around than a normal stem or just longer? I have a set of the same rims on my VW and if I knew how big the sensors were I 'd break a bead and look at the inside of the rim.
neuronbob
23
07-16-2019 10:48 AM
joflewbyu2
10-08-2015 11:16 AM
