D-100: The Official "Does This Wheel and/or Tire Fit My Car" Thread
#601
I'm raising a perch on the Koni's that should level things out... if I run into an issue with the fender I imagine it can be rolled out rather easily. I guess the real test is putting them on the car... should find out next week
#602
Not where I should be
Thanks,
help me understand, the 18x8's come in an offset of 35 while the 18x8.5's come in on offset of 30's, this is according to the Enkei site so without having to roll the fenders, which size would you recommend? also if you don't mind what size tire would fit best.
thank you so much for your help, it's greatly appreciated
#603
94 DC4 RS LSV/Turbo
When you say rub, are you speaking fender clearance, or clearance between when and suspension components.
If you raise your ride, you will have less chances of it occuring so you're good
#604
94 DC4 RS LSV/Turbo
Thanks,
18x8.5 +40
18x8 +35
245/40-18 is my suggested size, but 235/40-18 is factory spec which is also good
#605
Transmission: 6mt
Year/Trim: 04 A-SPEC
Wheel Make/Model: Gianelle Spezia-5
Wheel Size: 19x8.5
Wheel Offset: 38???
Lowered: A-SPEC kit
Alright guys I'm REALLY new to the whole wheels/tire/lowering combo thing so I'm not sure if the off-set is 38 or not on these wheels.
here is the link.
If you guys would look at them please and let me know if they would work and maybe what tire size to go with...sorry for the newbishness
Wheel Size: 19x8.5
Wheel Offset: 38???
Lowered: A-SPEC kit
here is the link.
#606
Transmission: 6mt
Wheel Size: 19x8.5
Wheel Offset: 38???
Lowered: A-SPEC kit
here is the link.
Wheel Size: 19x8.5
Wheel Offset: 38???
Lowered: A-SPEC kit
here is the link.
#609
Hello Fellaz,
I am new on this forum, well... because I bought my 2004 Acura TL only a week ago. It is bone-stock, 5AT,Navi. I was looking into swapping my stock 5 spokes with these below,
These are Bentchi B16s. According to their website the size is 18x7.5(I am only looking into putting 18s on my car, nothing bigger). I don't know what the offset is. Given that I won't be lowering my car and looking for "flush" look, what size of tires am I looking for? Also, I heard that with 7.5 width tires you can only go 235, otherwise tires will be wearing out quicker and it ain't safe. Is that true?Oh, and I know they will fit my car because the bolt pattern is 5x114.3. Any help is appreciated.
#610
[Mod Censored Title]
Hello Fellaz,
you should search this site before making a wheel decision (unless you're dead-set on those). you can get a good idea of what looks good on a TL here. IMO the TL is a very difficult car to match wheels to (cosmetic-wise).
btw...just because the bolt pattern is correct does not mean the wheel will fit your car...just ask all these guys on this site with Brembo's. if possible always test fit the wheel beforehand. good luck!
#611
Enkei rpf1 RC ..
18x9 Offset 18 F
18x10 Offset 22R
OR
18x8.5 Offset 42
18x9.5 Offset 45
what tire size is best ?
Im running 19x8.5 +38 235/35s tires seem real thin ride suck daily driving planning to upgrade suspension set-up as well
18x9 Offset 18 F
18x10 Offset 22R
OR
18x8.5 Offset 42
18x9.5 Offset 45
#612
TL Type S
CE28N
offset: 47
Will this fit over the stock brembos?
Thanks in advance guys
Questions on Wheels
Wheel Make/Model: Volk Racing CE28N
Wheel Size (**X**): 17 X 8.5
Wheel Offset (+**): 47
If lowered (amount): Lowered on aspec suspension
Question on Brembo/Big Brake Clearance
Transmission (Manual or Auto): Auto
Year/Trim (04-07, Base or Type S): Type S (BBK)
Questions on Tires
Tire Make/Model: RE01R Bridgestone
Width/Sidewall-Diameter (***/**-**): 245/45/17
offset: 47
Questions on Wheels
Questions on Tires
#613
Magic Happens In
will these fit?
Transmission: 6mt
Year/Trim: 05 NBP
Wheel Make/Model: XXR 518
Wheel Size: 18x8.5
Wheel Offset: +48
Lowered: none. how low can i go with theese?
Transmission: 6mt
Year/Trim: 05 NBP
Wheel Size: 18x8.5
Wheel Offset: +48
#614
Magic Happens In
Oh yeah, i have one more question. Has anyone seen rims that are black with a little bit of white accents, kind of like the polished lip but white instead of polished. LMK
#615
94 DC4 RS LSV/Turbo
Hello Fellaz,
so fitment is not acceptible
18x8.5 Offset 42
18x9.5 Offset 45
with a 245/40-18 front and a 255/40-18 rear
CE28N
offset: 47
Questions on Wheels
Questions on Tires
offset: 47
Questions on Wheels
Questions on Tires
http://cgi.ebay.com/18-XXR-518-Black...3286.m20.l1116
#616
Work Varianza-Schwert SC1
Questions on Wheels
Wheel Make/Model:Work Varianza-Schwert SC1
Wheel Size (**X**):19x8.0
Wheel Offset (+**):+45
If lowered (amount):probably 1"-1.5"
Will these fit? What type of tires will I need?
#618
#619
Questions on Wheels
Wheel Make/Model:2006
Wheel Size (**X**):19x8.5f and19x9.5r
Wheel Offset (+**):+38
If lowered (amount):2inches
Im thinkin about ADR spartan, does it fit perfect under the car cause it is a deep dish wheel. What tire size would you recommend me?
#621
[QUOTE=stillhere153;11028534]18x7.5 is too narrow for this car and is not a recommended size
I would go with te second of the 2
18x8.5 Offset 42
18x9.5 Offset 45
Thank you. prob get them within the month
18x8.5 Offset 42
18x9.5 Offset 45
#622
NBP REPRESENT
im looking at the mrr GT1...dont know whether i want black or silver...
19x 8.5 all around(what offset, im thinking +35 is better, dont want to run spacers anymore)
also what tire to run 235/35/19 or 245/35/19?
looking at bridgestone re960
im lowered on tein s techs...
also will i need a camber kit?
#625
94 DC4 RS LSV/Turbo
the face of the wheel will prevent clearance you will need to run a 10mm spacer
#628
i am upgrading from second gen tl to third. i have 17x 7 msr's on my 2000. i havent picked up my new tl yet 06. its auto tran base model. do the all have brembos? will these wheels fit? i think they are a little narrow. but will they clear everything and its just a tire issue?
17x 7 40mm offset
2006 tl base?
at
msr 113? i think
17x 7 40mm offset
2006 tl base?
at
msr 113? i think
#630
94 DC4 RS LSV/Turbo
17x 7 40mm offset
2006 tl base?
at
msr 113? i think
17x 7 40mm offset
2006 tl base?
at
msr 113? i think
04-06 Manual
07-08 ALL S Trims
those wheels are too narrow for the tl... you will need atleast a x8 +45
#632
Questions on Wheels
Wheel Make/Model:Axis Pentas
Wheel Size (**X**):19x8.5 and 19x9.5
Wheel Offset (+**):What offsets should I be looking at?
If lowered (amount):A small drop in the future.
My girl and I are flying up to New York this weekend to pick up her 07 Type S (automatic) and driving it back to Houston. We have been checking out wheels this past week and I'm really digging the Axis Pentas. We would like the staggered look and would like to run a 245/35/19 and a 275/30/19. I've read about the the bigger brakes up front possibly causing clearance issues. What should I be looking at in regards to offset to run these wheels on this car? If I have to roll the fenders that won't be an issue. If a minimal spacer is needed to make this setup work we are ok with that as well. We may or may not lower the car. If we did it would be minimal just to close up some of the fender gap but we would not be slamming the car.
Any help is greatly appreciated.
Carlos
Carlos
#633
Wheel Make/Model:Menzari M SPORT
Wheel Size (**X**):18" x 9.5"
Wheel Offset (+**):35
Wheel Make/Model:Platinum 200 Apex
Wheel Size (**X**):18"x8"
Wheel Offset (+**):40
I have an 04 tl will either of these be alright
#635
'07 NBP TL
Question on Brembo/Big Brake Clearance?
Transmission :Auto
07, Base
Wheel:Work Varianza t1s
Wheel Size:19x8.5
Wheel Offset : not sure.
If lowered:~1.5"
Also should I be getting the R Disk? One more thing, what does Full Reverse mean?
Also what size tires should I be getting? 225/35/19?
Transmission :Auto
07, Base
Wheel Size:19x8.5
If lowered:~1.5"
#636
NTMD8
Transmission :Auto
05 Base
Wheel:Konig Crosshairs
Wheel Size:19x8 - Front 19x9.5 - Rear
Wheel Offset : 30+ front 25+ rear
If lowered: Stock, but plan on dropping with Tein S-tech
http://cgi.ebay.com/ebaymotors/ws/eB...id=p2759.l1259
Normally i don't like staggered but the price looks good to me and i'm digging the style.
Will this fit? and recommended tire size?
05 Base
#637
94 DC4 RS LSV/Turbo
Questions on Wheels
Carlos
Carlos
if you plan to lower then you will have to modify your front fender slightly
#639
94 DC4 RS LSV/Turbo
either works with the tire specs... and if your car is not equiped with brembos it will be fine, if your car is equiped with brembos only the 18x8.5 +35 will fit
#640
94 DC4 RS LSV/Turbo
Transmission :Auto
07, Base
Wheel Size:19x8.5
If lowered:~1.5"
Transmission :Auto
07, Base
Wheel Size:19x8.5
If lowered:~1.5"
