D-100: The Official "Does This Wheel and/or Tire Fit My Car" Thread
#561
I Need Help
Looking at this package deal.
Zinik Wheels: 18 X 7.5
Tires Yohokama Parada Spec 2: 225/40R/18
I have a Type S 07.
I don't believe this will fit?
Any answers out there.
Sean
I have a Type S 07.
Sean
#562
94 DC4 RS LSV/Turbo
Question on Brembo Brake Clearance
Transmission: Manual
Year/Trim: 04
Wheel Make/Model: Kyowa KR120
Wheel Size: 18x7.5
Wheel Offset +45
Tire Size: 235/40/18
If lowered: H&R sports
Looking to find out what size spacers to use with this. I have a set of 20mm project kicks which work for the front but didn't run anything in the back. I'm looking to know what size would be good enough to clear the calipers up front 10 or 15mm? Also if I use the 20mm in the back, will my tires rub on the fenders?
Thanks for your help
Year/Trim: 04
Wheel Size: 18x7.5
Wheel Offset +45
My first post here; ok i need your advice ASAP. I found a killer deal on the TE37 bronze. And everybody know that the TE will get sold so fast...
will it fit?
Wheel Make/Model: TE37
Wheel Size (**X**): 18x9.5
Wheel Offset (+**): +40
If lowered (amount): n/a
Vehicle: 2005 A-Spec TL AT
Questions on Tires
Tire Make/Model:Any recommendation??
Width/Sidewall-Diameter (***/**-**):Which size??
And will these wheel will fit the BBK front 14" and rear 13"?
I am planning to get them by the beginning of summer.
thank god for this thread...
will it fit?
Questions on Tires
255/35-18 all around
#564
94 DC4 RS LSV/Turbo
235 is not compatible with 7.5... most tire manufacturer's will state that in their limited warranty... soooo again
x7.5 is .5" bellow factory spec... course you can install them, but do so if you are getting those rims for like 50% off or something
#566
Help me with tires!!!!!!
Wheel Make/Model: STERN ST-2
Wheel Size (**X**): 19x8.5, 19x9.5
Wheel Offset (+**): +32, +38
If lowered (amount): H&R Sport 1.5
Transmission (Manual or Auto): AUTO
Year/Trim (04-07, Base or Type S): 04 Base
WHAT TIRES DO YOU GUYS RECCOMEND???HELP!!!!!
#569
94 DC4 RS LSV/Turbo
they are over 3% larger than factory spec... would either rub on bumps but the speedo is the biggest worry, your speedo will be reading waaaay off
#570
#571
what tires size do you recommend? and also what about the size of the wheel with offset will it work ok?
Wheel Make/Model: ADR BATTLE EXE
Wheel Size (**X**): Front 19x8.5, Rear 19x9.5
Wheel Offset (+**): +35, +35
If lowered (amount): nothing yet if i were to drop most would be a inch
Transmission (Manual or Auto): 6spd manual
Year/Trim (04-07, Base or Type S): 05 with navi
thanks!
thanks!
#572
94 DC4 RS LSV/Turbo
no its the speedometer it will be thrown off if you get tires that are to big... tires which are 3% larger or smaller than oem spec are considered unsuitable by industry standards
#573
94 DC4 RS LSV/Turbo
thanks!
thanks!
front
235/35-19
245/35-19
rear
245/35-19
255/35-19
255/30-19
265/30-19
#576
sorry i found the other thread by searching then I couldn't see it anywhere so when I searched again I found this one so I posted it here too.
So they should clear the brakes and be good on rubbing? Thanks man I think I will be getting these then. I found them for a really really good price
#577
94 DC4 RS LSV/Turbo
in all likelyhood they should clear... worst case a 3mm spacer would be needed and then that would mean you'd have to run 235/35-19 tires but will sit nice and flush no rubbing
#578
Fantastic thread! nice work guys! From reading the posts, it seems like most 18x8 +35 rims will clear the brembos (except for rims like the Axis widetrack). How do you tell if a rim is like the widetrack?! Will these rims fit? Thanks!
Transmission (Manual or Auto): Manual
Year/Trim (04-07, Base or Type S): 05 base
If lowered (amount): 1.5" in front and 1" in rear
Wheel #1:
Wheel Make/Model: Axis Penta
Wheel Size (**X**): 18x8
Wheel #2:
Wheel Make/Model: Tenzo dc-5
Wheel Offset (+**): +37
Wheel #1:
Wheel #2:
#579
Will this work for me?
Transmission: Auto
Year/Trim: 2004 base
If lowered (amount): 1" in front and 1" in rear A-Spec springs
Wheel
Wheel Make/Model: SEVAS/ S-STAR
Wheel Size: 19x8.5
Wheel Offset: +30
Transmission: Auto
Wheel
Wheel Size: 19x8.5
Wheel Offset: +30
#580
94 DC4 RS LSV/Turbo
Wheel #1:
Wheel #2:
Wheel #1:
Wheel #2:
Penta's have a big lip, I've heard they require a 3mm to 5mm spacer
Wheel 2
Requires a 5mm spacer I know this for a fact
As for how I can tell... I just been on here way too long
#584
Someone is selling the following rims/tires and i'm wondering if the REARs will fit. Fronts are 19x8.5, +35. No problem here. Here are the dimensions for the REAR:
Wheel Make/Model: Axis Hiros
Wheel Size (**X**): 19x9.5
If lowered (amount): 1" in rear
#586
94 DC4 RS LSV/Turbo
Thanks! I assume with a 5mm spacer, there won't be any rubbing.
#587
Does the rear also have Brembo? For me, it seems like the rear doesn't have Brembos. Looking at other 3G users, most people seem to be running 19x9.5 +40 in the REAR... I'm worried +35 will rub when I lower the car
thanks again for your help! you do a lot of us a big help in our continuous frustrating hunt to find rims which clear the brembos!
#588
94 DC4 RS LSV/Turbo
oooh sorry you are talking rears I thought you ment the FRONT
depends on your tire choice... if you roll the fenders you will be ok with 245/35-19
#589
New shoes on my
Al,
Question for you on this:
Wheel Make/Model: Stern ST-1
Wheel Offset (+**): +45
If lowered (amount): A-Spec for MT. .75" rear, 1" front.
Transmission (Manual or Auto): Auto
Year/Trim (04-07, Base or Type S): 08 Base
I'd like to push the wheels out a bit. Looking at 15mm or 20mm spacers. Will that cause rubbing issues? I'm going to be using 245/35/19 tires.
Also, looking at the Willwood BBK in the future. Will it clear with that offset and the spacers? Thanks in advnace.
#590
Wheel Make/Model: Enkei ???
Wheel Size (**X**): 18x7.5
Wheel Offset (+**): ?
Year/Trim (04-07, Base or Type S): 07 Base
heres the rim just thought i put it in for a more descriptive look
http://honolulu.craigslist.org/oah/pts/1176298872.html
i was thinking of putting a 15mm spacer or should i go 20mm?
this route is cheaper then getting brand new tires
#591
94 DC4 RS LSV/Turbo
Al,
do not go larger than 10mm, wheeladapter.com makes a nice one or ichibausa.com
#592
94 DC4 RS LSV/Turbo
#594
94 DC4 RS LSV/Turbo
Will these clear the front brakes on a type-s ?
https://acurazine.com/forums/showthr...1#post10923120
mmmh I don't think so it looks like they are made to have wide lips... ask him to take pics of the backside thats the only way you could tell
#595
MY KBP IS BTR THN URS...
#596
Wheel Make/Model: 04 A-spec
Wheel Size (18x8.5):
Wheel Offset (+45):
If lowered (amount):~2.5" front ~2.25" rear
Toe is set in line. Front camber is set at -1.2* FL and FR. Rear camber is set at -2* RL and RR.
I know a 245/40-18 will fit all day, and obviously the 235/40-18 will fit as well. Question is:
Given the nature of my drop... will the 265/35-18 tire rub. How many people have ran a similar setup. I've seen references to a 265/35 on the 18x8 A-spec... I've seen people run the 265/35 on the stock 17 as well... I haven't been able to find a rear definitive answer as to whether the 265-35-18 will work on a rather aggressively lowered car without any issues.
Wheel Offset (+45):
#597
Not where I should be
Wheel Make/Model: Enkei RPF1
Wheel Size: 18x7.5 48 Offset
or 18x9.5 35 Offset
Transmission: Auto
Year/Trim: 04 Base
Lowered about 2" on Tein SS
or 18x9.5 35 Offset
Transmission: Auto
Year/Trim: 04 Base
#599
94 DC4 RS LSV/Turbo
Wheel Offset (+45):
Wheel Offset (+45):
#600
94 DC4 RS LSV/Turbo
bad fitment, it will fit but its a bad fitment, I wouldn't run them unless I got them for like $500
you need 18x8 or 18x8.5
rear
it will be nice and aggressive but you will need to roll the fenders to run real tires
